Home > Maintenance & Modifications > JW Speaker driving on the right
bear100
Getting ready for my run through France and the thought just crossed my mind about head light alignment while drive on the right?
My Range Rover is just an option to change in one of the menus but not so simple with the Defender, I have the JW Speaker headlamps and wondered if there is a way to achieve it other than using a piece and card then placing the stickers? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #848904 9th Aug 2020 7:31pm
grafty99
There isn't a way of adjusting the JWSpeakers. When I go abroad I just dip the lights a bit with the adjustment screw (2 full turns on the screw usually does it).
The legal requirement is that you don't dazzle so dipping the lights is enough - without needing tape etc Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #848917 9th Aug 2020 8:19pm
Bluest
It might be that they are like the Trucklites. They have flat beam with no kick up so no need to adjust those. It’s fairly easy to tell is you shine them on a wall. 2007 110 TDCi Station Wagon XS
Post #848918 9th Aug 2020 8:22pm
bear100
Thanks for the tip Grafty Thumbs Up
Bluest ism sure i have heard that before....probably on here!
I will give it a go.
Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #848919 9th Aug 2020 8:26pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
driven many times through france and never had an issue. Fingers crossed we are off again Friday night.
Post #849333 11th Aug 2020 4:14pm
bear100
I checked it out against my wall and there’s no lift at the end it’s a straight beam! So no need to adjust.....I think Confused
Stayed in Viollette on our way down last night it was 38c when we arrived at 5pm and cooled to 28c at 6am this morning, I’m one of those who sweats easily so it was a ruff night! Just what I wanted for the 300 miles today to Chamonix.....and it’s a decent 24c at the moment! 2023 Defender L663 V8
Post #849344 11th Aug 2020 5:25pm
