![]() | Home > Td5 > Injector Tolerances |
TD5Neil Member Since: 02 Nov 2017 Location: Cambridgeshire Posts: 42 ![]() ![]() |
Mine were all close, +/- 1-4. I don’t know how far out is out of tolerance though.
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 910 ![]() ![]() ![]() |
I think +/- 1-5 is good and anything up to 7 is acceptable. 19 is totally off. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Was the -19 at idle or under load?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
I had 2 injectors way out of trim. It was the early warning sign of head gasket failure. Since replacing head gasket (and a new head) all the injectors are within a few points. Nothing definite but worth considering
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Dexterdog Member Since: 23 Jun 2018 Location: gloucestershire Posts: 108 ![]() |
Thanks for the responses.
It was semi under load. The car only hesitates / misses just before the turbo spools up. Once you have it revving, it goes very well and you can actually drive it hard and drive straight through the problem. The reading was just as it was stuttering as I was holding it at the right point on the accelerator just before the turbo spools up properley. Interestingly I cannot get it to miss a beat when its stood still. When stationery I can search for the point in the revs for it to miss and it doesnt happen but when going along i can find the point just before the turbo spools up and hold it there. In low ratio it will kangaroo. When driving along at 50mph, it hesitates and stutters but momentum dulls down the effect compared to low ratio slow speeds. |
