Home > Td5 > Injector Tolerances
Dexterdog
Injector Tolerances
Hi,
Still chasing a hesitation / misfire on my 2001 TD5.
Live data showed the injector balance tolerance to be varying. One or two of them was as far out as -19 on occasions. A couple never went far off the graph pattern and stayed around -4
Tried googling but cannot find info. Is -19 indicative of a dying injector ?
Thanks
Post #848633 8th Aug 2020 8:07am
TD5Neil
Mine were all close, +/- 1-4. I don’t know how far out is out of tolerance though.
Post #848685 8th Aug 2020 3:11pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I think +/- 1-5 is good and anything up to 7 is acceptable. 19 is totally off. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #848714 8th Aug 2020 8:31pm
rallysteve
Was the -19 at idle or under load?
Post #848716 8th Aug 2020 8:47pm
grafty99
I had 2 injectors way out of trim. It was the early warning sign of head gasket failure. Since replacing head gasket (and a new head) all the injectors are within a few points. Nothing definite but worth considering Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #848718 8th Aug 2020 8:57pm
Dexterdog
Thanks for the responses.
It was semi under load. The car only hesitates / misses just before the turbo spools up. Once you have it revving, it goes very well and you can actually drive it hard and drive straight through the problem. The reading was just as it was stuttering as I was holding it at the right point on the accelerator just before the turbo spools up properley.
Interestingly I cannot get it to miss a beat when its stood still. When stationery I can search for the point in the revs for it to miss and it doesnt happen but when going along i can find the point just before the turbo spools up and hold it there. In low ratio it will kangaroo. When driving along at 50mph, it hesitates and stutters but momentum dulls down the effect compared to low ratio slow speeds.
Post #848733 8th Aug 2020 10:21pm
