![]() | Home > Technical > Traction control |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
have you checked all the sensors make sure they are all in place make sure the alignment is ok check for any lose wires the loom runs from the passenger side
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 ![]() ![]() |
Hi Yes I had mechanic run diagnostic and the rear wheel driver side wasn't showing soo changed sensor and its still the same .
Having no experience with repairing abs/TC systems on a tdci but I have with my D3.
Most off the time it is or the wiring or the sensor is not working partly or at all. If the wiring is faulty you should get an open circuit message. However the open circuit message can also come up if the sensor failed completely. Is the fault always present and does it come back directly after resetting? If the fault only shows up after a few meters off driving your sensor is partly faulty. Every fault has a number and you can google that. It might give more info then the faultcode reader that has been used. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
