Home > Technical > Traction control
sjc501
Traction control
Hi coukd be coincidence but just had brakes and discs on my tdci Puma . Now my traction control
Light is coming intermittent. Thought is was one and sensor so had it changed . Still
The same . Any advice
Post #847769 3rd Aug 2020 10:59am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
have you checked all the sensors make sure they are all in place make sure the alignment is ok check for any lose wires the loom runs from the passenger side
Post #848182 5th Aug 2020 10:54am
sjc501
Hi Yes I had mechanic run diagnostic and the rear wheel driver side wasn't showing soo changed sensor and its still the same .
Post #848462 6th Aug 2020 10:23pm
roel
Having no experience with repairing abs/TC systems on a tdci but I have with my D3.
Most off the time it is or the wiring or the sensor is not working partly or at all.
If the wiring is faulty you should get an open circuit message.
However the open circuit message can also come up if the sensor failed completely.
Is the fault always present and does it come back directly after resetting?
If the fault only shows up after a few meters off driving your sensor is partly faulty.
Every fault has a number and you can google that. It might give more info then the faultcode reader that has been used. Roel
2003 90 Td5 (2009-now)
Post #848479 7th Aug 2020 7:00am
