Home > Maintenance & Modifications > Fitting a new exhaust....on the drive?
bear100
Well my new Demand engineering exhaust has turned up Mr. Green
Is it a DIY job to fit on the drive?
Or best left to a garage? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #846712 28th Jul 2020 5:07pm
mk1collector
Easy diy if you have basic tools and ramps make it easier. Ray
My build thread
Post #846714 28th Jul 2020 5:10pm
Co1
Piece of cake. Make sure you’ve got the right gaskets and an angle grinder will be helpful for the stubborn bolts!
Post #846724 28th Jul 2020 5:49pm
discomog
Would be nice to see some photos when fitted. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #846726 28th Jul 2020 5:56pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
On my 90 td5 it was doable but ther front and rear sections were a bit difficult to get in and over the rear axle. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #846734 28th Jul 2020 6:11pm
bear100
Going to give it a go!!
Do i need any jointing paste? 2016 Range Rover Autobiography 4.4 TDV8
Post #846747 28th Jul 2020 7:14pm
Mine turned up today too.
Mine will be fitted on the drive, along with a transfer box Very Happy
Post #846754 28th Jul 2020 7:40pm
DEF4
Def 90 TDCI. Fitted mine on the drive - needed to drop rear anti roll bar to fit rear section. Easy to remove old silencers by cutting through pipes in several places with angle grinder.
Post #846783 29th Jul 2020 5:47am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Very easy on a 110! I think I just had to remove a mud flap.
Post #846785 29th Jul 2020 6:15am
roel
I only use paste if tubes go over each other but with a complete new exhaust it should be flanges that are bolted together so no paste needed. Roel
Post #846841 29th Jul 2020 11:27am
Ianh
Removing and fitting the rear exhaust section is made easier by jacking and supporting the chassis on stands. This allows the rear axle to drop creating wiggle room.
Flange sections with gaskets should not need paste, if your exhaust has slip joint sections with clamps then a high temp silicon such as permatex ultra copper RTV silicon [url] https://www.permatex.com/products/gasketin...le=en[url] is so much better than a paste that hardens then breaks up. Plus you don’t need so much clamping force which avoids denting slip joints and aids removal at a later stage if required. Noting this is more of an issue with mild steel pipes with thin walls as opposed the harder stainless steel sections.
You can use this high temp silicon on flange joints in addition to gaskets if you want to be 100% certain , especially when connecting to an old flange that has corrosion.
Note: you do need to wait a few hours for the silicon to set before starting engine.
Post #846851 29th Jul 2020 12:03pm
bear100
Well it’s in Very Happy
A couple of alignment issue but sorted it out
One question, the heat shield around the turbo used a fixing on the heat shield around the old cat now it’s just loose on the bottom is there a solution? 2016 Range Rover Autobiography 4.4 TDV8
Post #846853 29th Jul 2020 12:25pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Pics?
Post #846855 29th Jul 2020 12:49pm
