Home > Technical > Brake vacuum pump 2.4 tdci
Hjalle459
Sweden
Hi!
I’m in the middle of changing my vacuum pump on the side of the road 😅 and the new pump comes with two o-rings that the old one didn’t have? Anyone know where these two should go?
Post #845241 22nd Jul 2020 12:10pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Welcome
'Afraid I can't help you directly but this thread https://www.defender2.net/forum/topic20997.html?highlight=manual will help with a Workshop Manual download.
Good luck Very Happy Just because you're offended doesn't mean you're right.
Post #845247 22nd Jul 2020 12:53pm
jst
On the long nuts where oil way contacts top water housing? Is there not a gasket there? this is speculation trying go recall from when I changed water pump on mine. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #845251 22nd Jul 2020 1:14pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hjalle459, when I changed the water pump in the gasket kit, those o´ring were not there, only the sheet metal gasket! What happened to the old vacuum pump?
Post #845675 24th Jul 2020 10:23am
