![]() | Home > Technical > Brake vacuum pump 2.4 tdci |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Welcome
'Afraid I can't help you directly but this thread https://www.defender2.net/forum/topic20997.html?highlight=manual will help with a Workshop Manual download. Good luck ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8180 ![]() ![]() ![]() |
On the long nuts where oil way contacts top water housing? Is there not a gasket there? this is speculation trying go recall from when I changed water pump on mine. Cheers
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 93 ![]() ![]() ![]() |
Hjalle459, when I changed the water pump in the gasket kit, those o´ring were not there, only the sheet metal gasket! What happened to the old vacuum pump?
