Home > Technical > EGR Self cleaning
totoD110
EGR Self cleaning
after several times of using two stroke oil in my fuel. I never heard of my EGR self cleaning sound after engine shutdown...
Does anyone using 2 stroke has the same experience or something wrong with my EGR?
Thanks in advance. Smile
Post #79702 10th Jul 2011 12:45pm
Grockle
if you start the engine for a few minutes on switching off you should hear it(like a scrapping noise)this is when its on the cleaning cycle,two stroke won't effect it 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #79707 10th Jul 2011 1:12pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Maybe through using the 2 stroke oil there is no longer any carbon to scrape off?
Steve
Post #79709 10th Jul 2011 1:16pm
Naks
I have been using 2SO since truck was new and I always hear the EGR self-cleaning cycle. --
Post #79716 10th Jul 2011 2:40pm
galawaygreen
2010 Defender 90 Puma 2.4 XS CSW Galway Green
Perhaps it's not working Sad
Post #79717 10th Jul 2011 3:33pm
ickle
Mine is much quieter after using 2so, also it needs the occasional tap with a stick, but thats the internal contacts on mine......... Rolling Eyes
If its stuck your MIL will illuminate as well.
Post #79719 10th Jul 2011 4:08pm
spudfan
Ireland
Three years on and mine can be heard self cleaning. Always did from new. It is probably designed to do this whether it needs to or not to stop deposits building up. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #79735 10th Jul 2011 6:50pm
totoD110
Thanks guys for the swift replies. Bow down my engine is running stronger & smoother with 2SO but the only missing is egr cleaning sound. ickle is right if I have problem with my EGR I should get a MIL light. Maybe, all of my exhaust system are clean that doesn't need cleaning Whistle
Post #79745 10th Jul 2011 8:19pm
MK
2 SO in fuel will increment nitration in engine oil. Nasty stuff to for your bearings....... Rolling Eyes Puma 110" SW
Post #79788 11th Jul 2011 10:04am
Naks
Is that why adding 2SO to a TD makes it run quieter & more smoothly? --
Post #79793 11th Jul 2011 10:44am
My EGR valve is noisy when cleaning (like all Defenders and Transits seem to be). My main dealer commented not long ago that the valve was noisy and asked to replace it (I said no, since it has not got any noisier in the last year/30k miles), but he then said that there are now specific fuel additives intended to lubricate the EGR valve. He didn't say what, though.
I also run with 2SO and it does seem to make everything run more smoothly. I haven't noticed any difference on the EGR valve however.
Post #79794 11th Jul 2011 10:48am
Steve B
What % does it increase by? and what to?
Steve
Post #79795 11th Jul 2011 10:55am
MK
Course not. Engine oil needs to be replaced more often. Puma 110" SW
Post #79796 11th Jul 2011 11:15am
totoD110
after almost empty tank last few days I filled up w/o 2 SO and I heard the EGR cleaning again.. its strange Shocked
Post #79896 12th Jul 2011 8:00am
MK
Apparently some EGRs are seldom stuck (cuasing no problem at all) and some get fully open or closed (MIL should shout). IMHO I would not worry about the MIL. Cool Puma 110" SW
Post #79911 12th Jul 2011 9:35am
