Home > Technical > EGR Self cleaning |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
after several times of using two stroke oil in my fuel. I never heard of my EGR self cleaning sound after engine shutdown...
Does anyone using 2 stroke has the same experience or something wrong with my EGR? Thanks in advance. |
10th Jul 2011 12:45pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 |
10th Jul 2011 1:16pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
I have been using 2SO since truck was new and I always hear the EGR self-cleaning cycle. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
10th Jul 2011 2:40pm |
galawaygreen Member Since: 16 May 2011 Location: Lincolnshire Posts: 132 |
Perhaps it's not working
10th Jul 2011 3:33pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1802 |
Mine is much quieter after using 2so, also it needs the occasional tap with a stick, but thats the internal contacts on mine.........
If its stuck your MIL will illuminate as well. |
10th Jul 2011 4:08pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4729 |
Three years on and mine can be heard self cleaning. Always did from new. It is probably designed to do this whether it needs to or not to stop deposits building up. 1982 88" 2.25 diesel
10th Jul 2011 6:50pm |
Thanks guys for the swift replies. my engine is running stronger & smoother with 2SO but the only missing is egr cleaning sound. ickle is right if I have problem with my EGR I should get a MIL light. Maybe, all of my exhaust system are clean that doesn't need cleaning
10th Jul 2011 8:19pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2441 |
2 SO in fuel will increment nitration in engine oil. Nasty stuff to for your bearings....... Puma 110" SW
11th Jul 2011 10:04am |
Is that why adding 2SO to a TD makes it run quieter & more smoothly? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
11th Jul 2011 10:44am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
My EGR valve is noisy when cleaning (like all Defenders and Transits seem to be). My main dealer commented not long ago that the valve was noisy and asked to replace it (I said no, since it has not got any noisier in the last year/30k miles), but he then said that there are now specific fuel additives intended to lubricate the EGR valve. He didn't say what, though.
I also run with 2SO and it does seem to make everything run more smoothly. I haven't noticed any difference on the EGR valve however. |
11th Jul 2011 10:48am |
11th Jul 2011 10:55am |
Course not. Engine oil needs to be replaced more often. Puma 110" SW ............................................................. Earth first. Other planets later |
11th Jul 2011 11:15am |
after almost empty tank last few days I filled up w/o 2 SO and I heard the EGR cleaning again.. its strange
12th Jul 2011 8:00am |
Apparently some EGRs are seldom stuck (cuasing no problem at all) and some get fully open or closed (MIL should shout). IMHO I would not worry about the MIL. Puma 110" SW
12th Jul 2011 9:35am |
