Home > Puma (Tdci) > Coolant cap leak
Greyman110
Coolant cap leak
Question is...why?
Faulty cap?
Dodgy pressure?
Something else?
I’ve bought a new cap but I’m away.
Put PTFE tape around the thread but hasn’t made a difference.
Any ideas?
Post #843133 11th Jul 2020 1:11pm
Fit a better cap:
More details here: https://www.defender2.net/forum/post710243.html#710243 Darren
Post #843142 11th Jul 2020 2:49pm
Greyman110
Thanks...Think I might get that!
Would a leak make my temperature gauge intermittently go up? It now seems to occasionally do this but then goes back to normal. Also accompanied by momentary loss of power!?
Post #843174 11th Jul 2020 6:20pm
Hmm, that may warrant a bit of further investigation beyond just fitting a new cap. How much water have you lost? If it's enough to cause high engine temps then there could be a more significant underlying problem. It's unlikely to be intermittent, though. Are you topping it up between incidents or is it just an intermittent problem? If the latter then it may be an issue with the water temp sensor rather than something more drastic.
The loss of power sounds like a symptom of the indicated high temperature. I believe that the engine goes into a restricted performance mode if high temps are detected as a sort of self-preservation measure. Darren
Post #843210 11th Jul 2020 11:09pm
jst
the gauge going to the top could be electrical fault and that gives loss of power as a response to that.
However if your loosing coolant through the cap, sounds like over pressure of system. How long does it take from cold start to start leaking? There is obviosuly a pressure release in the camp.
Do the coolant hoses go hard?
Can you see bubbling in the expansion tank?
If you put heater on hot does it blow hot the whole time or vary red hot to cooler then repeat? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #843225 12th Jul 2020 6:26am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
The coolant system vents via the cap and will run all over the bottle.
I suggest you have another issue.
Are you loosing coolant?
The temperature gauge will not move between 85 deg to 110 deg C
It will only move at 115 deg then it will go straight to red.
The engine will de-rate at 115 deg hence your loss of power.
More info needed
Year of manufacture
KM's
other symptoms.
Post #843230 12th Jul 2020 6:58am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
what year is you defender ? pumas are prone to faulty caps iv had two on mine is your viscos fan working they can stick so you will overheat
Post #843238 12th Jul 2020 7:50am
Greyman110
Thanks for the input.
It’s a 2009 with 86k miles. Been solid last few years I’ve had her. I do 3-5k miles pa. it’s remapped with silicon hoses and bigger inter cooler.
There’s no other issue. On a 140 mile journey the other day it happened twice.
Usually happens 20 mins after start up then random.
Everything feels normal except for this.
This happened once before and I took it in to be looked at. Had EGR properly blocked off, like for like new remap and other valves changed. It seemed to fix the issue but it’s suddenly come back.
Post #843264 12th Jul 2020 9:33am
Greyman110
Just to add, I’m not losing loads of coolant. I topped up before I left to make sure it was to the line and I haven’t had to top it up. I’ll check again tomorrow before I leave just to make sure.
Post #843266 12th Jul 2020 9:36am
Naks
those coolant caps should be considered a service item.
I replace mine every year, it's dirt cheap. Thumbs Up --
Post #843275 12th Jul 2020 9:56am
Greyman110
I’ll do that as the first option and see if it makes a difference.
I also have a nanocom which didn’t show any issues.
Post #843276 12th Jul 2020 10:01am
jst
any thoughts on other questions? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #843327 12th Jul 2020 2:54pm
Greyman110
I haven’t felt the hoses and I haven’t noticed any bubbling but I have heard hissing coming from the cap after a journey.
I haven’t tried the heater. When I’ve noticed the gauge going up I’ve come off the accelerator which made it start to come down but last couple of times it didn’t make a difference and went up to max.
Post #843367 12th Jul 2020 5:16pm
jst
Change cap see what you get but I think its more than that
, check the hoses for pressure and what heater does wrt to temp changes.
9ne of my 2.4s did a head and gasket and temp gauge never moved off normal! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #843378 12th Jul 2020 6:08pm
Greyman110
Thanks. I have a long drive tomorrow so will check how things are then.
Post #843407 12th Jul 2020 8:48pm
