Home > Maintenance & Modifications > Revert LED Headlights?
BlueIn2Red
United Kingdom 2005 Defender 90 Td5 XS CSW Bonatti Grey
Hi guys, my TD5 90 has halo style LED headlights, which I'm not too keen on. Is it a straight swap to change to Wipac "Crystal Clear" lights with xenon bulbs please, or is the wiring totally different? I'm assuming probably the latter, which takes it out of the realm of something I would do myself.
Thanks in advance for any help.
Post #838931 22nd Jun 2020 4:30pm
bear100
I believe they are all the same H4 plug so should be a simple swap, add stainless lamp bezels and screws at the same time
Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #838942 22nd Jun 2020 5:09pm
Don’t blame you, I like LED but not those Halo ones.
As mentioned above, they should be H4.
They might, however, have tapped feeds from the sidelights above hence the halo ring. If so just unplug if it has connectors, if hard wired just isolate the ends of those so they are safe and can be tucked away.
Only take out the headlight retainer screws and don’t touch the alignment screws. You’ll see the difference.
After it’s done and the above SS bezels and screws are a good idea you might want to get them aligned at an MOT station. (Costs peanuts)
Whilst the beam adjustment wouldn’t be altered by you, the change will likely alter the beam pattern all the same.
👍🏻 $W33T $0U7H3RN $UG4R
Post #838991 22nd Jun 2020 6:38pm
BlueIn2Red
Thanks a lot guys, I went ahead with this and all went fine as you suggested. The wiring was indeed wired in with the sidelights/indicators, but I was able to just unplug this (leaving part of the LED wiring in place, which at the time meant I thought it wouldn't work properly), and everything worked. I'm much happier with the look of the new headlights, far more fitting with the rest of the vehicle in my opinion.
Post #839344 24th Jun 2020 10:32am
discomog
I'm not a fan of halo headlights, in fact SWMBO always comments on Defenders with halo's when they are coming towards us. I'll not quote her exact words.
Glad your conversion went ahead ok. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #839346 24th Jun 2020 10:37am
