The Zee
Hufflepuff wrote:Interesting, I've not come across Dun-Bri before.
Their website seems to be on the blink at the moment and won't allow me to look at the individual parts, but I see them at:
https://www.dun-bri.com/catalogue/results.aspx?search=95mm
Pity they don't do a box set with them all in, but I guess this way you can pick'n'mix the parts. Thank you for the suggestion.
Dun-Bri are a commercial suppler/distributor: they supply the likes of the AA, RAC and major conversion companies with response lighting, and alternative fittings.
So it may be that Twisted, MudUK and others purchase from Dun-Bri or an equivalent distributor. Dun-Bri normally supply 100's of a single unit, not 1 or 2. The webshop is just a “sideline” and everything they stock is not listed online, and why it is a "pick n mix" system, where items are listed by use or manufacture, it's not really designed for general use. Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
17th Jun 2020 6:13am |
