Home > Puma (Tdci) > Propshaft replacement [solved]
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
After replacing the clutch I have shifted the problem to the front prop UJ which is squeaking like a rubber-duck now.
My car is lifted by 2''.
Any recommendations on how to improve this part of drive-line?
I am thinking on Double Cardon wide angle propshafts.
Cheers!
edit: [SOLVED] Janusz
www.yahodeville.com
Post #79080 5th Jul 2011 11:41am
Zagato
I had a bit of squeaking and vibration from a 1.5" lift as a result of putting parabolics on my 109. It all settled down after a while and has been fine since Thumbs Up
Post #79081 5th Jul 2011 11:45am
yaho
In my case it goes worse every day.
Started week ago (few days after clutch change) as shy, vague whistle.
Today it is loud squeak, squeak, squeak... Janusz
www.yahodeville.com
Post #79088 5th Jul 2011 12:20pm
The UJ's normally suffer when the car is lifted....It's best to put castor correction arms on really, then a wide angled prop is a good bet also...
Just replacing the uj will cure your squeek for a while, but will soon come back.
Post #79090 5th Jul 2011 12:55pm
MK
IMHO for Pumas it is compulsory to fit a CV propshaft+castor correction bushes or radius arms. Unlike prevoius Defenders, the engine and drivetrain are tilted back 6º. FYI std front propshafts are arlready wide angle in Pumas. Puma 110" SW
Post #79100 5th Jul 2011 3:26pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
2" lift and double cardon front prop for me - only very mild vibration but decided not to put any more strain than necessary on the other components
Post #79153 5th Jul 2011 10:32pm
yaho
Replaced (new and old on the picture).
See how much damage was done on the old propshaft.
It has done 46.000 km, last 12.000 the car was lifted by 2''
All the clunking, squeaks, transmission backlash has gone - it sounds now like any other car Very Happy
Seems strange - I can hear nothing now Confused
 Janusz
www.yahodeville.com
Post #81140 20th Jul 2011 7:52am
Can I ask where you guys got your DC props from? I don't suppose the front prop from a Disco2 fits (I have a spare)?
Thanks.
Post #81178 20th Jul 2011 1:22pm
yaho
I have got it from here: http://nakatanenga-tours.de/ (part PSZDGDETD4HDFL)
Few others have it, but were not available for immediate shipment.
Overview of my inquires:
Nakatanenga (GKN) - 649 EUR vat incl.
Gwynlewis4x4 (Bailey Morris) - 420 GBP excl. vat
Famous Four - not available
Devon4x4 - late with reply, available but they need exact length of a prop-shaft
Paddockspares - not available ("We are not aware of anybody who are selling these parts for a Puma")
Cheers! Janusz
www.yahodeville.com
Post #81183 20th Jul 2011 2:34pm
nakatanenga
Germany
And ours is the "bigger" HD Version of the double knuckle, fully greasable! WANTED:
SII or SIII in max 1.5k
Post #81189 20th Jul 2011 3:49pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
i had a 2" lift and noise was bad, put in a new double propshaft and the problem was gone, any lift on a TD4 will need a replaced Propshaft.
I have to wait till my new 110 comes (with the 2,2 motor) so i can fit heavyduty suspension with a 2" lift and i'm sure i'll need a new propshaft too.
Post #81278 20th Jul 2011 8:58pm
Landyrob
hey nakatanenga
thanks for your glove box, it's fantastic, will sure be back to shop with you guys again Very Happy
Rob
Post #81282 20th Jul 2011 9:03pm
nicknick
England 2010 Defender 90 Puma 2.4 CSW Tonga Green
How much!! Shocked
we get truck propshafts custom made when we stretch truck wheelbases, these are sometimes 4inches diameter tube and 6 feet long, these only cost a couple of hundred quid.
contact Dunning and Fairbank at Leeds (google them) and they will make watever propshafts you want at a reasonable price.
Thumbs Up
Post #81286 20th Jul 2011 9:09pm
. Will be going this route soon
Post #81301 20th Jul 2011 9:38pm
nakatanenga
Germany
Nick,
i am always keen to get a better quote BUT the problem is the double knuckle! It is only available from 3 companies and GKN is the only one that lasts! And GKN is not the cheapest company Sad WANTED:
Post #81367 21st Jul 2011 10:06am
