Home > Puma (Tdci) > Propshaft replacement [solved] |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
After replacing the clutch I have shifted the problem to the front prop UJ which is squeaking like a rubber-duck now.
My car is lifted by 2''. Any recommendations on how to improve this part of drive-line? I am thinking on Double Cardon wide angle propshafts. Cheers! edit: [SOLVED] Janusz www.yahodeville.com Last edited by yaho on 20th Jul 2011 6:54am. Edited 1 time in total |
5th Jul 2011 10:41am |
In my case it goes worse every day.
Started week ago (few days after clutch change) as shy, vague whistle. Today it is loud squeak, squeak, squeak... Janusz www.yahodeville.com |
5th Jul 2011 11:20am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
The UJ's normally suffer when the car is lifted....It's best to put castor correction arms on really, then a wide angled prop is a good bet also...
Just replacing the uj will cure your squeek for a while, but will soon come back. |
5th Jul 2011 11:55am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
IMHO for Pumas it is compulsory to fit a CV propshaft+castor correction bushes or radius arms. Unlike prevoius Defenders, the engine and drivetrain are tilted back 6º. FYI std front propshafts are arlready wide angle in Pumas. Puma 110" SW
5th Jul 2011 2:26pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
2" lift and double cardon front prop for me - only very mild vibration but decided not to put any more strain than necessary on the other components
5th Jul 2011 9:32pm |
Replaced (new and old on the picture).
See how much damage was done on the old propshaft. It has done 46.000 km, last 12.000 the car was lifted by 2'' All the clunking, squeaks, transmission backlash has gone - it sounds now like any other car Seems strange - I can hear nothing now Click image to enlarge Janusz www.yahodeville.com |
20th Jul 2011 6:52am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
Can I ask where you guys got your DC props from? I don't suppose the front prop from a Disco2 fits (I have a spare)?
Thanks. |
20th Jul 2011 12:22pm |
I have got it from here: http://nakatanenga-tours.de/ (part PSZDGDETD4HDFL)
Few others have it, but were not available for immediate shipment. Overview of my inquires: Nakatanenga (GKN) - 649 EUR vat incl. Gwynlewis4x4 (Bailey Morris) - 420 GBP excl. vat Famous Four - not available Devon4x4 - late with reply, available but they need exact length of a prop-shaft Paddockspares - not available ("We are not aware of anybody who are selling these parts for a Puma") Cheers! Janusz www.yahodeville.com |
20th Jul 2011 1:34pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
And ours is the "bigger" HD Version of the double knuckle, fully greasable! WANTED:
SII or SIII in max 1.5k |
20th Jul 2011 2:49pm |
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 |
i had a 2" lift and noise was bad, put in a new double propshaft and the problem was gone, any lift on a TD4 will need a replaced Propshaft.
I have to wait till my new 110 comes (with the 2,2 motor) so i can fit heavyduty suspension with a 2" lift and i'm sure i'll need a new propshaft too. |
20th Jul 2011 7:58pm |
hey nakatanenga thanks for your glove box, it's fantastic, will sure be back to shop with you guys again Rob |
20th Jul 2011 8:03pm |
nicknick Member Since: 28 Feb 2011 Location: halifax Posts: 30 |
How much!!
we get truck propshafts custom made when we stretch truck wheelbases, these are sometimes 4inches diameter tube and 6 feet long, these only cost a couple of hundred quid. contact Dunning and Fairbank at Leeds (google them) and they will make watever propshafts you want at a reasonable price. |
20th Jul 2011 8:09pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
. Will be going this route soon |
20th Jul 2011 8:38pm |
Nick,
i am always keen to get a better quote BUT the problem is the double knuckle! It is only available from 3 companies and GKN is the only one that lasts! And GKN is not the cheapest company WANTED: SII or SIII in max 1.5k |
21st Jul 2011 9:06am |
