![]() | Home > Puma (Tdci) > mysterious noise |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4767 ![]() ![]() |
Yesterday I noticed vibrating noise comming from the drivers side of the engine.It only appeared when comming off the accelerater.Today in daylight and with the help of Mrs. Spudfan I found the cause.It was a loose bracket holding the heatshield in place over the turbo.It just needes tightened.Thought I would post it incase someone else experienced it. 1982 88" 2.25 diesel
Well diagnosed. Was it a buzzing noise or a rattle (I appreciate that's a slightly subjective question). |
Sounded like a roughness when easing off the accelerator.Was very loud when I pulled the bonnet and pushed then released the pedal by hand.Today when the mrs. worked the pedal I could see a shudder in the heatshield as she came off the revs.I did not know if it was the heatshield or the turbo.All the bolts on the heatshield seemed tight.Then I noticed a bracket that is bolted to the engine just behind the pulleys was vibrating so I tightened the bolt holding it and the problem was solved.Sounds complicated but it is the only way I can describe it.Anyway it was very easily cured once I found the problem.I am glad I did not go to a garage with it but it was bothering me last night.Eduardo could probably put up a diagram of the turbo and heatshield and the bracket would be easily seen then.He is normally very good with those things. 1982 88" 2.25 diesel
Genius. Thanks. Makes complete sense.
If only everything was as easily solved! 1982 88" 2.25 diesel
Thanks spud,and yes if only. 2.4 90 XS
