Home > Puma (Tdci) > mysterious noise
spudfan
Ireland
mysterious noise
Yesterday I noticed vibrating noise comming from the drivers side of the engine.It only appeared when comming off the accelerater.Today in daylight and with the help of Mrs. Spudfan I found the cause.It was a loose bracket holding the heatshield in place over the turbo.It just needes tightened.Thought I would post it incase someone else experienced it. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #5573 16th Dec 2008 8:12pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Re: mysterious noise
Well diagnosed. Was it a buzzing noise or a rattle (I appreciate that's a slightly subjective question).
Post #5582 16th Dec 2008 11:57pm
spudfan
Ireland
Sounded like a roughness when easing off the accelerator.Was very loud when I pulled the bonnet and pushed then released the pedal by hand.Today when the mrs. worked the pedal I could see a shudder in the heatshield as she came off the revs.I did not know if it was the heatshield or the turbo.All the bolts on the heatshield seemed tight.Then I noticed a bracket that is bolted to the engine just behind the pulleys was vibrating so I tightened the bolt holding it and the problem was solved.Sounds complicated but it is the only way I can describe it.Anyway it was very easily cured once I found the problem.I am glad I did not go to a garage with it but it was bothering me last night.Eduardo could probably put up a diagram of the turbo and heatshield and the bracket would be easily seen then.He is normally very good with those things. 1982 88" 2.25 diesel
Post #5584 17th Dec 2008 12:12am
alantd
Genius. Thanks. Makes complete sense.
Post #5585 17th Dec 2008 12:15am
spudfan
Ireland
If only everything was as easily solved! 1982 88" 2.25 diesel
Post #5586 17th Dec 2008 12:18am
Grockle
Thanks spud,and yes if only. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5592 17th Dec 2008 9:43am
