Home > Technical > Brake master cylinder 90 pre vs after 91 |
Fufflenarnia Member Since: 15 Feb 2020 Location: Redhill Surrey Posts: 13 |
Hi,
My master cylinder on my '92 90 is leaking. It looks like it has the pre90 cast master cylinder fitted not the later one as it should be (non abs). Is the later master cylinder better? Will it fit my servo? Is it worth changing into what should be fitted? Thanks all, |
4th Jun 2020 3:49pm |
Thanks James
4th Jun 2020 5:55pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
The two different master cylinders are not interchangeable as the stud positions on the servo are at a different angle.
They are slightly different piston bores (23.8mm vs 25.4mm) but the larger one was fitted from 91 (i.e. before rear discs were standard) so doesn't really matter which. I think the later ones are all three port and the earlier ones 2port so changing would need a servo and piping change. I would just use the same as the type you already have, just buy a good branded one! Steve 02' 110 TD5 Double Cab Rebuild Thread |
4th Jun 2020 5:58pm |
Ok, that makes sense, a bigger bore would mean less pedal travel, but maybe a pressing harder.
That said, it does look like a faff! I have a Delphi one priced up and on my basket, it seam the good old days of changing seals have gone! |
4th Jun 2020 6:18pm |
The trouble is that usually when they start leaking there will be corrosion and pitting within the cylinder bore so new seals won't last long at all.
4th Jun 2020 6:30pm |
