Home > General & Technical (L663) > Accessories
Page 4 of 6 <123456>
^^^^ Now that picture paints a thousand words that’s for sure. Choppers in the background, 20” rims etc.
Not a surprise at all, soon you’ll see camo wraps, being lowered. Blacked out windows and much of the same.
Won’t be long before a 6” exhaust version will be available or to suit with a cherry bomb mid silencer. 😂
Couldn’t be further from the roots it was supposed to have followed.. KEEP CALM AND Drill ON
Post #835752 7th Jun 2020 5:40pm
J77
Lucky 8 rock sliders
Post #838261 19th Jun 2020 11:30am
custom90steve wrote:
^^^^ Now that picture paints a thousand words that’s for sure. Choppers in the background...
I'd have thought LR's history with choppers is long established:
Post #838272 19th Jun 2020 12:17pm
Is that a normal panel gap?
Post #838273 19th Jun 2020 12:20pm
Tim in Scotland
Nothing like that on mine Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #838275 19th Jun 2020 12:27pm
RDR
I have a rule - never judge a panel gap by a photo but something doesn't look right. I don't think that front trim is clipped back in place which could makes sense as I think you have to remove it to get to the step mounting bracket and they will be playing with the fittings no doubt. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D5 MY19 HSE - Now Sold
D4 MY16 HSE Luxury - Now Sold
D4 MY12 HSE - Gone
D3 MY06 S - Gone but not forgotten
Post #838276 19th Jun 2020 12:29pm
J77
I think it’s still work in progress, it could be they’ve lost a trim clip or just not secured it yet.
Post #838279 19th Jun 2020 12:54pm
Supacat - I was’t talking about the Military. I was talking about private owned. KEEP CALM AND Drill ON
Post #838283 19th Jun 2020 1:24pm
I know ~ I was only joking. Your point is well made.
Post #838285 19th Jun 2020 1:39pm
Morepower
New Zealand
You'll need them as if you roll off any object and land on the sill structure, The vehicle could be a complete write off.... Which could get quite expensive if you actually intend to use it 'For its intended purpose'....
Not sure what the legal stance is for damaged sills on a monocoque vehicle as they are structural.... Anybody know???? It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #838299 19th Jun 2020 3:32pm
Morepower
New Zealand
Also, How are they mounted?... as any drilling into the chassis will be structural and that could weaken the structure in a crash... What would the legal implications of that be??.... And how would that effect the crumple zones?? If the chassis is designed to bend in a serious accident, but this stops it... then what will the next fail point be???... Here come the problems with adding parts to something that's not actually designed to have them added... It doesn't matter how bad it is, It can always get worse...
Post #838305 19th Jun 2020 3:37pm
spudfan
Ireland
Don't forget adding the idiot behind the steering wheel. This does not apply to any on Defender2 who might buy one as they will be more than capable of using the vehicle. I am thinking of the buyer who has no 4x4 experience, who swallows the hype and believes all he/she has to do is start it up, point in the direction required and assume the electronics will do the rest. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #838326 19th Jun 2020 5:10pm
J77
They fit in exactly the same place as LRs side steps and side tubes, I would imagine.
Post #838355 19th Jun 2020 7:22pm
Morepower
New Zealand
So they have been designed to have the same deformable structural qualities....Impressive engineering considering they won't have the numerical structural model from LR....Interestingly the genuine LR ones are aluminium and these are steel.... The properties of these two metals are quite different..... It doesn't matter how bad it is, It can always get worse...
Post #838364 19th Jun 2020 8:22pm
Morepower
New Zealand
The LR info states that on a 110 each step can carry 135kg... So it's just rally that... a step... it offers little or no sill protection... These will obviously be stronger... However LR will have engineered the std step to break long before the sill/chassis does... I would guess these are far far stronger than the LR originals.... So who knows what will fail first... most likely the mounting points as they aren't structurally designed to take that sort of loading...... It doesn't matter how bad it is, It can always get worse...
Post #838370 19th Jun 2020 8:36pm
