Home > General & Technical (L663) > Accessories |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
Lucky 8 rock sliders
Click image to enlarge |
19th Jun 2020 11:30am |
I'd have thought LR's history with choppers is long established: Click image to enlarge Click image to enlarge |
19th Jun 2020 12:17pm |
Is that a normal panel gap? Click image to enlarge |
19th Jun 2020 12:20pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Nothing like that on mine Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
19th Jun 2020 12:27pm |
RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 595 |
I have a rule - never judge a panel gap by a photo but something doesn't look right. I don't think that front trim is clipped back in place which could makes sense as I think you have to remove it to get to the step mounting bracket and they will be playing with the fittings no doubt. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
19th Jun 2020 12:29pm |
I think it’s still work in progress, it could be they’ve lost a trim clip or just not secured it yet.
19th Jun 2020 12:54pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20580 |
Supacat - I was’t talking about the Military. I was talking about private owned. KEEP CALM AND Drill ON
19th Jun 2020 1:24pm |
I know ~ I was only joking. Your point is well made.
19th Jun 2020 1:39pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
You'll need them as if you roll off any object and land on the sill structure, The vehicle could be a complete write off.... Which could get quite expensive if you actually intend to use it 'For its intended purpose'....
Not sure what the legal stance is for damaged sills on a monocoque vehicle as they are structural.... Anybody know???? It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
19th Jun 2020 3:32pm |
Also, How are they mounted?... as any drilling into the chassis will be structural and that could weaken the structure in a crash... What would the legal implications of that be??.... And how would that effect the crumple zones?? If the chassis is designed to bend in a serious accident, but this stops it... then what will the next fail point be???... Here come the problems with adding parts to something that's not actually designed to have them added... It doesn't matter how bad it is, It can always get worse...
19th Jun 2020 3:37pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
Don't forget adding the idiot behind the steering wheel. This does not apply to any on Defender2 who might buy one as they will be more than capable of using the vehicle. I am thinking of the buyer who has no 4x4 experience, who swallows the hype and believes all he/she has to do is start it up, point in the direction required and assume the electronics will do the rest. 1982 88" 2.25 diesel
19th Jun 2020 5:10pm |
They fit in exactly the same place as LRs side steps and side tubes, I would imagine. |
19th Jun 2020 7:22pm |
So they have been designed to have the same deformable structural qualities....Impressive engineering considering they won't have the numerical structural model from LR....Interestingly the genuine LR ones are aluminium and these are steel.... The properties of these two metals are quite different..... It doesn't matter how bad it is, It can always get worse...
19th Jun 2020 8:22pm |
The LR info states that on a 110 each step can carry 135kg... So it's just rally that... a step... it offers little or no sill protection... These will obviously be stronger... However LR will have engineered the std step to break long before the sill/chassis does... I would guess these are far far stronger than the LR originals.... So who knows what will fail first... most likely the mounting points as they aren't structurally designed to take that sort of loading...... It doesn't matter how bad it is, It can always get worse...
19th Jun 2020 8:36pm |
