![]() | Home > Maintenance & Modifications > Bulk Head Air Flaps Jammed |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
If you think it not the pins in the hinges try turning them by tightening the nut carefully. I think you will probably find it is the hinge pins. But rust treatment and working them should free them up or allow you to remove them. If they do move easy remove them and then you will be able to move the flap and see what is going on.
I replaced my pins with stainless steel ones ![]() |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 639 ![]() ![]() ![]() |
Definatly the hinge pins, the late pins seem prone to this. Be warned the nuts can snap off and also the bulkhead hinges are only spot welded on so cannot take much force with hammer and punch. One particularly horrible 2005 td5 I had I had to cut the flaps off and heat up the bulkhead hinges to remove the pins then respray the bulkhead top and fit new vent flaps.
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
At the risk of sounding ridiculous, I know that we do not get to use the vents very often in this country BUT you are remembering to move the lever over to the right before pushing it down
![]() Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
How do you move the lever to the right on a 2006 td5?
Sorry Just assumed they were the same as the Tdi. Jeff
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2277 ![]() ![]() ![]() |
On a TD5 you pull the round knob then push down.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
On my TD5 you have to move the lever to the right then down, like jeffersj said so I guess it might be year/model related on how you open them, if indeed you have them!
I recently had the flap on the LH side stick but that was due to it being closed for so long through the winter and the rubber/foam seal sticking to the flap. Gentle pressure eventually freed it. I made a jig to push the rusted pins out early on and then replaced them with stainless steel ones https://www.defender2.net/forum/topic46942.html Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Replacing my seized flap hinge pins a few days ago with stainless. After trying several methods, the way that worked the best was as follows. Take the nuts off both ends and spray plenty of WD40 or similar on the bulkhead part of the hinge. Carefully put mole grips on the threaded ends and then slowly apply pressure up and down to hopefully break the rust hold. The bulkhead part is rolled so WD40 should start to get in once pressure is applied to start to open it up a bit. Doing this there will be no going back to put the nuts back on but it worked for me. Once the pin starts to move you can then remove one set of grips and slowly work it out. Good luck!!! 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
You can always save yourself some pain and just put a few drops of 3 in 1 once a year on each hinge, saves them seizing and having to be replaced. Moving parts require lubrication
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
