Home > Maintenance & Modifications > Bulk Head Air Flaps Jammed
Parrottone
2006 Defender 90 2.5 n/a Diesel SW Baltic Blue
Hi,
The drivers side bulkhead air flap seems to be jammed on my 2006 TD5. The bolt above has minor rust so wouldnt think it is that. While using a small screwdriver on the outside to lever and see if it was the seals, all seems to be fine. My thinking is that the lever on the inside of the car is the thing that is stuck.
Any help would be great,
Thanks,
Henry
Post #832366 21st May 2020 11:54am
landy andy
If you think it not the pins in the hinges try turning them by tightening the nut carefully. I think you will probably find it is the hinge pins. But rust treatment and working them should free them up or allow you to remove them. If they do move easy remove them and then you will be able to move the flap and see what is going on.
I replaced my pins with stainless steel ones Thumbs Up
Post #832367 21st May 2020 12:06pm
Oldowner
Definatly the hinge pins, the late pins seem prone to this. Be warned the nuts can snap off and also the bulkhead hinges are only spot welded on so cannot take much force with hammer and punch. One particularly horrible 2005 td5 I had I had to cut the flaps off and heat up the bulkhead hinges to remove the pins then respray the bulkhead top and fit new vent flaps.
Post #832772 23rd May 2020 6:54am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
At the risk of sounding ridiculous, I know that we do not get to use the vents very often in this country BUT you are remembering to move the lever over to the right before pushing it down Whistle Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #832784 23rd May 2020 7:38am
Oldowner
How do you move the lever to the right on a 2006 td5?
Post #833248 25th May 2020 8:47am
jeffersj
Sorry Just assumed they were the same as the Tdi. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #833263 25th May 2020 9:50am
Mo Murphy
On a TD5 you pull the round knob then push down.
HTH
50 Shades of Pennine Grey
Post #833269 25th May 2020 10:41am
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
On my TD5 you have to move the lever to the right then down, like jeffersj said so I guess it might be year/model related on how you open them, if indeed you have them!
I recently had the flap on the LH side stick but that was due to it being closed for so long through the winter and the rubber/foam seal sticking to the flap. Gentle pressure eventually freed it.
I made a jig to push the rusted pins out early on and then replaced them with stainless steel ones
https://www.defender2.net/forum/topic46942.html Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #833348 25th May 2020 6:17pm
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Replacing my seized flap hinge pins a few days ago with stainless. After trying several methods, the way that worked the best was as follows. Take the nuts off both ends and spray plenty of WD40 or similar on the bulkhead part of the hinge. Carefully put mole grips on the threaded ends and then slowly apply pressure up and down to hopefully break the rust hold. The bulkhead part is rolled so WD40 should start to get in once pressure is applied to start to open it up a bit. Doing this there will be no going back to put the nuts back on but it worked for me. Once the pin starts to move you can then remove one set of grips and slowly work it out. Good luck!!! 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #833359 25th May 2020 6:42pm
Mo Murphy
You can always save yourself some pain and just put a few drops of 3 in 1 once a year on each hinge, saves them seizing and having to be replaced. Moving parts require lubrication Smile
Post #833410 26th May 2020 7:33am
