Home > Puma (Tdci) > 2010 key fob battery replacement
NCTT
Morning chaps
ive done a search , but its all a bit confusing , i need to change my key fobs on my remote
i see that the later models seem to be a bit more tricky , but raading up on it can a 2010 just be replaced without sitting in the car , reprogramming ect pls ?
i dont want to come a cropper with thee long w.e approaching !
many thanks as usual in advance guys
Post #832163 20th May 2020 10:52am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Extract from LR workshop manual:
Handset Battery
NOTE: Do not remove a battery until you are ready to install the replacement. Always fit a Land Rover STC4080 or a Panasonic CR2032 replacement battery.
1. Unlock the vehicle and disarm the alarm system.
2. Turn the ignition switch to position 'II', then turn to position '0' and remove the key.
CAUTION: Do not allow moisture to get inside the handset.
3. Carefully prise the handset apart, starting from the keying end. Avoid damaging the seal between the two halves of the case.
4. Slide the battery out of its clip, taking care to avoid touching the circuit board or the contact surfaces of the clip. 5. Press and hold one of the buttons for at least 5 seconds to drain any residual power from the handset.
6. Fit the new battery, making sure that correct polarity is maintained (+ve side facing up). Finger marks will adversely affect battery life. Avoid touching the flat surfaces of the battery, and wipe clean before fitment.
7. Reassemble the two halves of the handset. Operate the Padlock symbol button at least 4 times within range of the vehicle to resynchronise the handset.
Post #832165 20th May 2020 11:33am
discomog
It may be me but I'm not sure - are you wanting to just change the battery or the actual key fob? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #832166 20th May 2020 11:34am
NCTT
ahh that brilliant
lets see how it works in practice !!!
much appreciated chaps !
Post #832168 20th May 2020 11:40am
Balvaig
Works for me, change mine every 2 years. Sometimes forget and just changed the battery without following instructions. Still worked ok.
Just do one key fob at a time, and make certain it is working ok before doing the second.
Post #832196 20th May 2020 2:00pm
AMBxx
Oops - both times I've done it, I've just ripped out the batteries and put in new ones. Embarassed
Post #832204 20th May 2020 2:44pm
discomog
When mine went into the Land Rover dealer for its two year service the mechanic came out just before I drove away and said sorry but he'd left the fob batteries on his bench but no problem if I hung on for two minutes he's go and get the batteries and swap them over. He did this in the car park and both fobs worked perfectly ok so ever since I've just opened up the fob and swapped them over with no problems. Defender 90XS SW
Morgan Plus 8
Post #832212 20th May 2020 4:08pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
changed mine I did not go through the procedure and has worked ok Smile
Post #832235 20th May 2020 5:44pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Just noticed that when I unlock mine, the indicators do not flash - I seem to recall this indicates the battery in the fob needs changing, but can anyone confirm please? Euro-Leafing to infinity and beyond.....
Post #832258 20th May 2020 7:20pm
andydef90
yes change your battery mate
Post #832336 21st May 2020 9:22am
strang
Thumbs Up cheers Euro-Leafing to infinity and beyond.....
Post #832446 21st May 2020 7:42pm
Zirmbach
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Santorini Black
thanks for this, worked a charm just now after 'oh s***' moment of removing before checking if there was a procedure, fortunately had a second set so could do the steps.
Post #950836 28th Apr 2022 1:10pm
spudfan
Ireland
Moved 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #950933 28th Apr 2022 11:10pm
TSAF
Greece 2015 Defender 110 Puma 2.2 HT Venetian Red
do you have to seat in the drivers seat while changing the battery fob? Or I got this totally wrong?
Post #1047452 2nd Oct 2024 10:24am
spudfan
Ireland
No. I do mine in the kitchen then go out and do the magic lock/unlock thing. 1982 88" 2.25 diesel
Post #1047472 2nd Oct 2024 2:08pm
