Home > Maintenance & Modifications > Defender Classic Works Suspension Help
darwin1
I just fitted the Defender Classic Works full kit (brakes, springs/shocks, ARB, and 18" Sawtooths).
Shipped the kit to Costa Rica and I had the install done here in CR by a very competent mechanic.
The front sits considerably lower now than the rear.
Trying to figure out If JLR sent me wrong parts or what else might have gone wrong.
Any help is greatly appreciated.
Post #831702 18th May 2020 3:03am
bankz5152
Thats how they sit Instagram @defender_ventures
Empire Tuning - Agent
Post #831703 18th May 2020 5:27am
grafty99
Looks normal to me too. 110s always sit rear end high Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #831712 18th May 2020 6:56am
Pilgrimmick
Perfectly normal, when loaded the rear end will settle and be lower. All to do with load capacity. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #831714 18th May 2020 7:20am
That's not normal. Whilst the front does sit lower, it's not that low.
Here's mine before and after fitting new, standard suspension:
 Darren
Post #831722 18th May 2020 7:57am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I would agree with LRA, definitely does not look normal.
Post #831740 18th May 2020 9:18am
Mo Murphy
Isn't the works kit suspension lowered ?
50 Shades of Pennine Grey
Post #831745 18th May 2020 9:41am
stephan123
Side view of Defender V8 Works as a reference (which i believe has same suspension set up), front clearly not sit that low.
Post #831747 18th May 2020 9:53am
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Mine standard height with bilstein b6. Yours don’t look normal.
Post #831750 18th May 2020 10:10am
camelman
Is the works engine lighter than a Puma unit?
Post #831752 18th May 2020 10:29am
Caterham
how disappointing for you.
something doesn't look right as you say - I hope you get it sorted. Please keep us posted. Thumbs Up
Post #831761 18th May 2020 10:44am
That's a good question although you'd have thought that LR would have factored that in, given that every other Puma is diesel. Darren
Post #831762 18th May 2020 10:47am
UtilityTruck
You may have ended up with the wrong springs. Are there any part numbers, colour codes or stickers on the springs you received?
Front springs for yours should be LR135108. The front springs for the V8 are LR135109. 2014 Keswick Utility 2.2
Post #831813 18th May 2020 3:47pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Works V8 fronts are different to the suspension upgrade puma fronts to account for the weight difference.
Post #831841 18th May 2020 6:48pm
JOW240725
It's not as simply as having fronts and rears the wrong way around?
Looks great by the way. Would be interested to hear how it performs when right. Good luck. James
Instagram @suffolk_rovers
Post #831895 18th May 2020 9:49pm
