Home > In Car Electronics > Clips holding live cable from battery box to driver seat box
kmac
Anyone know how the clips work? They are plastic and part look like a cable tie
There are two under the truck holding the live cable that goes from the battery to the driver seat fuse box.
I have actually cut the cable tie bits to remove the old cable but I want to route another cable in its place so want to replace the clips but cannot figure out how they are fixed to the car
Any help appreciated
Post #831615 17th May 2020 5:25pm
apachecow
1999 Defender 110 Td5 CSW Rutland Red
Are they the cable ties with a fir tree fitting?
https://www.ebay.co.uk/itm/5mm-Width-Black...SwjsdevQ-N
Post #831624 17th May 2020 5:42pm
apachecow
A pack of these are useful in the toolbox, too
https://www.screwfix.com/p/2-way-adhesive-...-100/80760
Post #831625 17th May 2020 5:44pm
kmac
Actually it is a clip which screws on to a threaded stud on the underside of the truck - it has an integrated cable tie.
I cut the cable tie but I can reuse the clip by cutting the remaining part of the cable tie and using another
[/url]IMG-0578 by [/img]
IMG-0580 by [/img]
IMG-0581 by [url=https://www.flickr.com/photos/152440487@N03/][/img]
Post #831641 17th May 2020 6:49pm
kmac
Thanks for the suggestion apache - not sure the stick pad one will survive underneath the truck, but useful elsewhere.
There are even magnetic base ones which I think would suit this application. As it turns out I will be re-using the originals.
Post #831642 17th May 2020 6:53pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
New clips and push onto the ribbed stud, part number below-
Post #831673 17th May 2020 8:32pm
kmac
Thumbs Up
Post #831674 17th May 2020 8:34pm
