Home > Technical > 300Tdi ignition Switch
buckers19
1993 Defender 90 300 Tdi CSW Barolo Black
When I go to turn the key on my 300tdi, it does not click into the positions, it just turns all the way to start the engine. If feels like a spring has broken or something similar.
What part do I need to replace it? It starts fine it’s just very frustrating when you only want to turn the radio on and the whole car bursts into life.
Cheers, Matt Instagram.com/mattbuckley19
Post #831373 16th May 2020 10:01am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
New barrel here https://www.jgs4x4.co.uk/land-rover-defend...-lr041320/ Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #831517 17th May 2020 8:05am
Stripygitface
Re: 300Tdi ignition Switch
Cheers, Matt
It is likely to be the switch that attaches to the barrel, easy removed only held on with a couple of screws.
If you take the switch off the barrel, the key has no resistance
Post #831578 17th May 2020 1:37pm
Martin
Site Admin
Indeed, replace the switch. PRC8230 / LR035359 / LR039638
Buy the best quality one you can afford.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #831604 17th May 2020 3:51pm
