![]() | Home > Technical > 300Tdi ignition Switch |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
New barrel here https://www.jgs4x4.co.uk/land-rover-defend...-lr041320/ Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Stripygitface Member Since: 16 Sep 2014 Location: Kent Posts: 81 ![]() |
It is likely to be the switch that attaches to the barrel, easy removed only held on with a couple of screws. If you take the switch off the barrel, the key has no resistance |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
Indeed, replace the switch. PRC8230 / LR035359 / LR039638
Buy the best quality one you can afford. ![]() ![]() |
