Home > Technical > Impact wrench
ibexman
Impact wrench
Hog ring or detention pin what do you have🤔
Post #830630 12th May 2020 9:21am
sako243
Hog on my big Milwaukee. The pin detents can be a pain if you're changing sockets regularly. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #830674 12th May 2020 12:06pm
Several of each.
Generally ring up to 1/2" drive, above that I prefer pin.
Post #830680 12th May 2020 12:19pm
Ianh
I’ve both. Prefer the hog ring, works well on my Milwaukee. I managed to break the pin on my dewalt and it’s no where near as powerful as the Milwaukee.
Post #830789 12th May 2020 8:43pm
discomog
I hate to be pedantic but I'm not sure that the retaining ring you're referring to is a hog ring. A hog ring is a connector used to fasten materials together using special pliers and is normally a permanent or semi permanent fixture.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #830816 13th May 2020 7:27am
ibexman
Well Mr Dewalt describes it as a hog ring
Post #830819 13th May 2020 7:49am
discomog
and so does Mr Milwaukee. Like Blackwolf I prefer ring and pin for 3/4 drive and spring ring for 1/2" drive Defender 90XS SW
Morgan Plus 8
Post #830821 13th May 2020 8:03am
My reasoning is that a pin is more secure. Having seen sockets come off impact wrenches more than once, if you are hit by a 3/8" or 1/2" square drive socket it will hurt but is unlikely to maim. A 1" square drive socket is quite likely to inflict life-changing injuries, and is far too heavy in my opinion to rely on spring ring for retention.
I am not aware that spring ring is even an option above 1" square drive, the only system I have seen in 1.1/2" or above is the retaining pin.
Post #830831 13th May 2020 9:17am
