Home > Maintenance & Modifications > 2" receiver or tow ball
Page 2 of 3 <123>
bear100
Checked the website, v5 and yes I pay the £270 tax so Ive got an N1
Looking at all the comments (thanks) a receiver is probably the way to go,
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #829788 7th May 2020 10:42pm
sako243
db950 wrote:
2” receivers aren’t Type approved for the UK.
I assume you mean that it is not type approved on the Defender.
Land Rover have offered 2" receivers on the Range Rover since at least 2007 from factory so they had to be type approved for them to sell them at that point. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #829832 8th May 2020 10:14am
There are (as far as I know) no Defender receiver hitch fittings that have been type approved.
There may be other vehicles for which TA fittings are available, and there may be things you can stick in a 2" receiver that are type approved, but there is no type approved way to mount them on a Defender.
I hope that this provides clarity!
Post #829839 8th May 2020 10:56am
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
There a very few TA 2” receivers, the Range Rover being one (if not all) but are manufacturer specific and TA for that vehicle only.
To my limited knowledge there are no aftermarket TA receivers available for any vehicle, but I stand to be corrected!
Post #829855 8th May 2020 11:42am
Welshsurferdude
Wales
I've had a 2" reciever on the back of mine for years, towed over 3.5 tonne no problem
when I'm not using it i just remove it and put it under back seats. nice to be able to swap between tow ball and recovery eye with ease. 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #830006 9th May 2020 7:01am
amschnellsten
United States 1986 Defender 90 Other SW Alpine White
BuckBlu110 wrote:
Just to add on what to what Bear100 has asked, would a 2” receiver and drop plate be ok for towing a horse box with two medium sized horses? So let’s say 2-2.5t that moves a bit.
you would still be way below the weight limit for the receiver. As a Yank that is mainly what we use until a 5th wheel. I've just came back from towing two defenders @ or above 90 mph for 10 hours so yeah, you should be fine.
Post #830585 12th May 2020 3:35am
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Thanks, I guess it’s no different in strength to a Dixon bate with a single pin drop plate which i currently have.
Post #830594 12th May 2020 7:48am
DAZ110
I think the pin is slightly thinner than the Dixon bate pin.
Post #830620 12th May 2020 9:59am
donmacn
db950 wrote:
Type approved came in on 01/08/98 for passenger vehicles (M1) but light commercials (N1) were exempt until 31/10/12 when it changed to all needing type approval.
All depends on the age of the Defender and if it was registered as a N1 commercial.
I’ve looked at 2” receivers before, and the always got bogged in the type approval/tax class thing.
So I searched and read a few more threads today and found this above.
I don’t actually know what my V5 says, but it might be irrelevant anyway! My car is a 1994, base spec 110 SW - first sold to a local airport fire brigade. Does the fact that it’s 1994 mean I don’t need to worry about type approval, and could legally tow my boat trailer (about 1.2T)?
I know, legal advice from a Defende forum… but you know what I mean! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #958364 14th Jul 2022 10:06pm
Yes, yours pre-dates the need for any type approval. Darren
Post #958504 16th Jul 2022 11:33am
donmacn
Thanks Darren, more stuff I’d read was bringing me closer and closer to that conclusion, but it’s good to get it supported.
Cheers Donald
in the past..
Post #958530 16th Jul 2022 5:02pm
bear100
I did indeed fit the 2" receiver and very please with it Thumbs Up 2023 Defender L663 V8
Post #958541 16th Jul 2022 6:38pm
kenzle8a
How do people find it with towing 3.5 tonnes? I can legally fit one, just looking at options for the farm as we have a few hook and loops and some nato hitch things
Post #958558 16th Jul 2022 9:19pm
I've regularly towed up to 3.5 tonnes on mine without any problems at all.
How do I find it? I look at the rear crossmember and there it is, nestling just underneath! Rolling with laughter
(Sorry, couldn't resist that one).
Post #958565 16th Jul 2022 11:32pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Not had any worries about having a weight up behind when using the 2inch receiver. Everything is still sound.
I know of a Chinese ebay special drop hitch that has started to fail, Shocked Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #958573 17th Jul 2022 7:50am
Page 2 of 3 <123>
