Home > Technical > Brake shields remove or replace
Remove or replace brake shield
Remove
42%
 42%  [19]
Replace
57%
 57%  [26]
Total Votes: 45
bear100
While upgrading my brakes all round i noticed the brake shields are corroded and look awful, I recall a discussion many moons ago about replacing them or just removing them
There’s pros and cons for both but what do the majority of you think?
Remove and not replace
Or
Replace them
Are they mud traps? Stone traps? Useless? Stop cool air? Provide protection? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #828960 2nd May 2020 8:33pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I'm always getting a stone jammed, and I've more than once bent them while offroad, only to be alerted by a horrible whining noise and a burning smell as they rub on the brake disc. Its a dirty and difficult job to get underneath and bend them back again in the middle of nowhere.
They seem quite flimsy for protection, and I'd gladly be rid of them. However, would I be doing worse damage, to more important things, if they weren't there?
Post #828976 2nd May 2020 10:29pm
Retroanaconda
Really it depends on your use of the vehicle.
If you do heavy muddy off roading then take them off as they will trap mud/stones and make cleaning difficult.
For normal driving and standard green laning type off roading then leave them on. They prevent excessive brake wear on the rear pads particularly and also keep a lot of road spray off the discs which helps with braking after driving on wet roads (motorways especially).
Post #828981 2nd May 2020 10:54pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
It would be great if you could get galvanized ones!
Post #828984 3rd May 2020 5:58am
bear100
There are galve ones out there at around £50 each Shocked
Looked at another site just now and they had a poll on the same question, with the exception of 2 or 3 everyone said remove a lot said it’s one of the first jobs they do! 2023 Defender L663 V8
Post #828990 3rd May 2020 7:06am
Thon
Echoing above, I would keep them on - I do quite a lot of wading and muddy fun stuff and have found that it's a minor inconvenience to have a bit of light squeaking. The benefit of keeping the road spray off the discs is one worth having - never much fun waiting for the pads to clear the spray off the discs when you most need them. They won't protect your brakes from anything much apart from the spray but they're worth it for that IMHO.
Post #829132 3rd May 2020 10:00pm
Mo Murphy
I'm told there is a benefit of less wear in the rear pads. Has anyone else found this ?
50 Shades of Pennine Grey
Post #829160 4th May 2020 9:09am
I have certainly found that rear pad life becomes greatly extended as soon as the rear calipers seize, which they are rather prone to doing. The downside is that the rate of wear on the front pads accelerates! Rolling with laughter
Post #829175 4th May 2020 9:44am
Retroanaconda
When I was doing a lot of forest road miles I used to go through a set of rear pads in less than 5,000 miles due to road spray laden with grit. Putting the rear guards back on resolved this entirely.
Post #829178 4th May 2020 9:58am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
My first 90 had shields till the front ones fell off.
My Camel Disco had the shields too.
My D3 G4 V8 had the shield but was mainly used on the road.
My current 90 td5 had shields but I took them off.
All these Land Rovers used more rear brake pads than front brake pads at almost 2 to 1. Only the D3 is was about 1 1/2 to 1.
A day off-road in wet sand eats my rear pads and most off the front pads. And I don't have TC Mr. Green Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #829246 4th May 2020 5:22pm
keith
I think the question being asked is.
“Should I replace” ( looks good, easy and clean ) NO EFFORT. Vs
“should I refurbish” ( scrape, prime, paint ) LOTSA EFFORT.
It’s a throwaway world and too easy to pickup the phone and new shiny part arrives the next day. I as others have done just this many times. But it’s a time of austerity and if your saving the pennies then no option but refurbish.
I also asked this very question about this very part only yesterday as I replaced a new disk and shocker.
So, I refurbished. Scrape, wire brush, bleeding knuckle and some primer and paint later.
Good as new. Perhaps in another 8yrs I’ll treat myself to a new one. Very Happy
Post #829264 4th May 2020 6:43pm
Eduardo
Humm...
Both rear brake shields almost was destroyed due stones in Tierra del Fuego. So finally I decided to do not replace it.
Cheers Eduardo
Post #829268 4th May 2020 7:01pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Down here on unsurfaced roads in the winter the pads can wear out in as little as 3 weeks in extremely poor conditions. Not having the guards on accelerates the wear considerably - I once took them off a vehicle I had and fairly quickly put them back on again! They don't stop pad wear in extreme conditions but they do slow it down by keeping most of the hurricane of gritty mud and water outside the wheel.
The problem with the guards here is usually fatigue cracking rather than corrosion, so new is the only option unless you like trying to weld up coke can metal. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #829361 5th May 2020 10:39am
Neilios
England 1997 Defender 110 300 Tdi HCPU Keswick Green
I like to replace them as that’s how they are meant to be, here’s my process for a rebuild on a vehicle planned to spend most of its time on the road towing and carrying things.
New parts.
Blasted parts
Galvanised for a long life
But if it was for a mud plugger, pay and play or competition vehicle they would be removed. Hope that helps you decide what’s best for you. 1997 110 Hi-Cap Keswick Green
1997 90 Truck Cab Blue
1996 Discovery Pickup
Post #829452 6th May 2020 5:36am
donmacn
I think I noticed in one of the mags this month that Britpart are now supplying them galved.
I've not much doubt that a proper DIY job as above will give better results, but for ease it might be an option. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #829486 6th May 2020 9:09am
