Home > Technical > Fitting the power steering fluid reservoir on 300tdi
iceshj
Hello all. It’s been 3 yrs since I pulled this car apart and I can for the life of me remember how the reservoir is secured in the engine bay of my 300tdi defender. Any tips appreciated
 Defender 90 softop (in bits)
Range Rover Hybrid SVAutobiography
Discovery 3 HSE
Kawasaki ZX12R
Post #826238 18th Apr 2020 3:40pm
dorsetsmith
left hand drive i no but shown it mounted on side engine bay left hand side
right hand drive shown mounted on side engine bay left hand side too
Post #826239 18th Apr 2020 3:48pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Two holes on the l/h wing area (r/h as you look into the engine bay) can’t miss it really with those pics Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #826266 18th Apr 2020 6:19pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Love that horn, must get one.
Post #826269 18th Apr 2020 6:48pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Whats the wire coming from the EGR blanking plate ?
Post #826292 18th Apr 2020 9:14pm
Mountain_man
Wales
That will be an exhaust gas temperature probe. I used to have one on mine. It will be connected to a guage on the dash giving temperature read out. Essential if you have tweaked the pump to within an inch of its' life and want to make sure you aren't destroying your engine when pulling hard up hills.
Post #826322 19th Apr 2020 7:58am
Mountain_man
Wales
This is a retro fit 300 tdi set up in a early 110. You can see that I have put the reservoir in the usual place but it is mounted by a short bracket to one of the triangular wing/slam panel bracket lower fixing bolts.
Post #826323 19th Apr 2020 8:06am
iceshj
Thanks guys. The trouble I had, is that I replaced the wing and it didn’t have holes in to make it obvious. A moment of inspiration this morning made me look at the other wing and I found the holes mentioned, so just had to get the drill out. Thank you all for your help Defender 90 softop (in bits)
Discovery 3 HSE
Kawasaki ZX12R
Post #826483 19th Apr 2020 9:17pm
