Home > Series Land Rovers > Second tank how does it work |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 |
That looks cool. It looks like it has a sender unit in it. If you fill the tank you normally use, does the gauge read full?
14th Apr 2020 5:39pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17538 |
That is the style of twin-tank set-up used on military Land-Rovers, and you should find that the changeover switch has an electrical switch on the back, so that the fuel gauge reads the sender from whichever tank the feed is being taken from.
Effectively you have two independent tanks, you are only ever using one, determined by the position of the switch. They are not linked and you fill them independently. Simple, robust, reliable, just like Land-Rovers used to be. |
14th Apr 2020 5:52pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3784 |
Hello
Thanks my series is a safari model with seemingly quite a few 'options' 👍 I did move the switch over to the other tank and switched the ignition round, didn't start the car. The fuel gage read the same as the normal tank, but there is no fuel in the left hand tank. Thanks |
14th Apr 2020 6:46pm |
It may be that whoever fitted the tank didn't connect up the sender, or it may even be that the change-over tap doesn't have the switch attached, it rather depends who fitted the tank and how good a job they did. It might be worth looking at the back of the change-over tap to see what if anything is there.
14th Apr 2020 7:04pm |
Racedriver Member Since: 24 Jan 2019 Location: Buckinghamshire Posts: 114 |
I suspect it would be simpler to fit a second gauge rather than trying to get the original to work with both sides. Or use the side without the gauge first, always keeping the other side as reserve.
18th Apr 2020 5:38pm |
Much depends on who put it in and what they put it in for with regard to the plumbing.
Mine worked just as Blackwolf described, but when I put a diesel engine in the fuel return only ran to one tank. After fuelling both tanks you had to be very careful to run from the return tank first, and make space for returning fuel from the 2nd tank before changing over. |
19th Apr 2020 8:39am |
