Home > Series Land Rovers > Second tank how does it work
Stacey007
Hello
On my series it had the second tank under the passenger seat. With the lever RH / LH under the drivers side.
I tried to undo the cap thought it would be solid and to my surprise it opened. It had the same style filler as the car that pulls out (up).
My question...the fuel gage I guess is my normal tank. If I switch over to the other tank using the level does it use the fuel from their also? As I moved the lever to LH and the fuel level still read the same? Yet there is no fuel in the extra tank.
It looks immaculate inside but I have not put anything in to see if it leaks etc..
Would I need another fuel gage? I'm confused 😲
Post #825273 14th Apr 2020 5:18pm
Huttopia
That looks cool. It looks like it has a sender unit in it. If you fill the tank you normally use, does the gauge read full?
Post #825278 14th Apr 2020 5:39pm
That is the style of twin-tank set-up used on military Land-Rovers, and you should find that the changeover switch has an electrical switch on the back, so that the fuel gauge reads the sender from whichever tank the feed is being taken from.
Effectively you have two independent tanks, you are only ever using one, determined by the position of the switch. They are not linked and you fill them independently. Simple, robust, reliable, just like Land-Rovers used to be.
Post #825280 14th Apr 2020 5:52pm
Stacey007
Hello
Thanks my series is a safari model with seemingly quite a few 'options' 👍
I did move the switch over to the other tank and switched the ignition round, didn't start the car. The fuel gage read the same as the normal tank, but there is no fuel in the left hand tank.
Thanks
Post #825303 14th Apr 2020 6:46pm
It may be that whoever fitted the tank didn't connect up the sender, or it may even be that the change-over tap doesn't have the switch attached, it rather depends who fitted the tank and how good a job they did. It might be worth looking at the back of the change-over tap to see what if anything is there.
Post #825311 14th Apr 2020 7:04pm
Racedriver
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
I suspect it would be simpler to fit a second gauge rather than trying to get the original to work with both sides. Or use the side without the gauge first, always keeping the other side as reserve.
Post #826260 18th Apr 2020 5:38pm
Much depends on who put it in and what they put it in for with regard to the plumbing.
Mine worked just as Blackwolf described, but when I put a diesel engine in the fuel return only ran to one tank. After fuelling both tanks you had to be very careful to run from the return tank first, and make space for returning fuel from the 2nd tank before changing over.
Post #826328 19th Apr 2020 8:39am
