Home > Off Topic > Sheds - buying online
Page 2 of 4 <1234>
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
+1 tiger sheds Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #825071 13th Apr 2020 8:57pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
excossack wrote:
A long lasting shed. Probably when shed paint contained all the good stuff and not a water based one.
My grandad gave us a shed he'd had for around 40+ years for the scouts bonfire. He'd treated it every year with something I'm pretty certain you'd need a licence to possess in todays society.
Needless to say it pretty much evaporated as soon as the first lick of flame touched it Shocked 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #825182 14th Apr 2020 11:38am
excossack
Probably engine oil and creosote. FiL used this on his gates/fence and is many years old. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #825189 14th Apr 2020 11:48am
walfy
Been a while since I built a shed, and then I probably over engineered it massively. But thinking of doing a project for a niece. She wants a 12' X 10' shed/summer house.
When I built mine years ago I built the frame from 2' X 2' and 400 centres. I think I had the right size timber but a bit to close on the centres. Trying to look at online pics and it's hard to see what they do. But I reckon they're about 600mm centres. Is that what you have with your built/bought sheds? 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #825202 14th Apr 2020 12:29pm
Rosco
The shed I bought a couple of years ago (cant recall where from though) is in 1m panels, and all interchangable so you could configure it any way round you wanted it.
Uprights are 25x25mm and 50x50mm for the roof trusses. Its withstood the recent bad weather without issue.
Assembled myself with the assistance of a friend over the course of a couple of evenings. If I was to do it again, I'd put more bearers under the floor as theres a little movement on one join in the floor. 2007 - Stornoway Grey 90 XS SW - Gone
Post #825203 14th Apr 2020 12:39pm
walfy
So the framework was 25mm x 25mm? That seems a little bit to small for me. 110 D250 SE HT
110 USW SOLD
Post #825205 14th Apr 2020 12:41pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Walfy ,What will you clad the shed with ? Decent thickness featheredge from timber merchants 600 centres will be fine . Very thin featheredge from some of the diy places 400 centres is likely not to be close enough to make a lasting job .
Post #825206 14th Apr 2020 12:44pm
walfy
I need to price up the various options for cladding. A lot will depend on her budget. So it looks like stronger frame for thinner/cheaper cladding or smaller size for frame and stronger cladding.
Now my thought process would be stronger frame and then you have the option of cheaper cladding if it needs repair.
But will speak to her and see what she wants. Would then need to draw up plans and a cutting list. So they can source the timber ready for a build 110 D250 SE HT
110 USW SOLD
Post #825212 14th Apr 2020 1:00pm
walfy
My initial thought was T&G but I think that will be to expensive for her. She has a modest budget but nothing huge 110 D250 SE HT
110 USW SOLD
Post #825215 14th Apr 2020 1:02pm
MartinK
If you do build yourself, as you are in the NW, these guys are great (and cheap!) for pressure treated timber (this is where I bought the materials for mine):
https://www.mdhanafin.co.uk/product-category/timber/
If you go to them with a decent bill-of-materials they will do you a good price. I planned mine well, and had just one plank left over at the end of the build Thumbs Up
I built mine line an internal stud wall (i.e. frame), then clad on the outside with 18mm x 150mm lengths. Rock solid...can walk about on the roof and it never moves at all.
Also I had 2nd hand french windows as the doors. In needed a concrete floor as I may put a heavy motorbike in there...
Plenty of cheep patio doors if you did go that way https://www.gumtree.com/p/doors-windows/patio-doors/1370599963 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #825223 14th Apr 2020 1:51pm
walfy
MartinK, I'm based in the SW not NW. But I'll sort a cutting list and just drop it in to a few timber merchants and see what comes back 110 D250 SE HT
110 USW SOLD
Post #825224 14th Apr 2020 1:58pm
Retroanaconda
Definitely worth building your own as you can control the cost-cutting measures that go into most examples, but there are good suppliers around for pre-made small to medium sheds. I would expect minimum of 75x45 for the wall framing and 19mm cladding (actual finished thickness not nominal). And proper roofing like Onduline - not horrible old felt - plus perhaps most importantly.... gutters!
If in doubt, over-engineer it. It’s what I’ve done!
Post #825226 14th Apr 2020 2:07pm
walfy
I like over engineering but it's not my budget or garden it's going in. So I will be constrained by her budget. But will advise to go big Very Happy .
She wants something like this
https://www.ebay.co.uk/itm/303216662591?fb...7oLroBtX-g 110 D250 SE HT
110 USW SOLD
Post #825228 14th Apr 2020 2:14pm
Rosco
Yep 25x25mm. Agree it looks a little small but as the panel sizes arent massive at 1m wide and 1.7m tall, plus they screw into the adjoining panel, it makes it pretty sturdy.
All came as a flat pack kit and no movement in the panels 2007 - Stornoway Grey 90 XS SW - Gone
Post #825230 14th Apr 2020 2:20pm
walfy
Thanks, My initial thought process was 50x50 for outer edges and either 50x25 or 25x25 for studs. But that sounds to complicated for my tiny brain.
So think I'll be making up 5' panels for the sides so need 2 of them and then 2 X 6' panels for the front which I can let a door into. 110 D250 SE HT
110 USW SOLD
Post #825231 14th Apr 2020 2:23pm
Page 2 of 4 <1234>
