Home > Maintenance & Modifications > fitting 300tdi fuel tank
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Hi Just ordering new fuel tank for a 300tdi 90 . What else would you suggest i order and will need ?
Many thanks for help in advance
Post #824647 11th Apr 2020 7:01pm
Mdm
your best to clean it and paint it before fitting as the paint they come with lasts 10 mins these days
then we waxoyl or similar .
i would also test the tank for leaks when when you have fitted the seals and pick up pipes etc plus it helps to check if there is any debris or swarf in there.
Post #824664 11th Apr 2020 7:39pm
Bathale
United Kingdom 1998 Defender 90 300 Tdi PU Rioja Red
Just fitted a new one to mine last week.
Order a new set of fittings and gaskets, some new tanks have them and some don’t. Check the rubber tank fill pipe carefully for cracks, mine was cracked and I only noticed when I when I went to refit it.
As already said, undercoat it especially underneath between the tank and tank guard, get as much under seal protection between to two parts (warm the under-seal in a bucket of warm water before applying)
Get new nuts and bolts X3 for the front tank mount to the chassis, it makes an awkward job a little easier.
Take your time and if you have a second set of hands so much the better...... I didn’t!
Good luck. 😎
Post #824702 11th Apr 2020 10:39pm
jst
make sure you get a pressure tested one. i fitted a britpart one once, it had three holes in it, they had even spray painted over the holes! should of checked it first! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #824720 12th Apr 2020 7:41am
Outlaw1
Thanks all for advice {no britpart } Thumbs Up
Post #824728 12th Apr 2020 8:13am
