Home > Maintenance & Modifications > fitting 300tdi fuel tank |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1631 |
your best to clean it and paint it before fitting as the paint they come with lasts 10 mins these days
then we waxoyl or similar . i would also test the tank for leaks when when you have fitted the seals and pick up pipes etc plus it helps to check if there is any debris or swarf in there. |
11th Apr 2020 7:39pm |
Bathale Member Since: 02 Sep 2016 Location: South West Posts: 100 |
Just fitted a new one to mine last week.
Order a new set of fittings and gaskets, some new tanks have them and some don’t. Check the rubber tank fill pipe carefully for cracks, mine was cracked and I only noticed when I when I went to refit it. As already said, undercoat it especially underneath between the tank and tank guard, get as much under seal protection between to two parts (warm the under-seal in a bucket of warm water before applying) Get new nuts and bolts X3 for the front tank mount to the chassis, it makes an awkward job a little easier. Take your time and if you have a second set of hands so much the better...... I didn’t! Good luck. 😎 |
11th Apr 2020 10:39pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8143 |
make sure you get a pressure tested one. i fitted a britpart one once, it had three holes in it, they had even spray painted over the holes! should of checked it first! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Apr 2020 7:41am |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 273 |
Thanks all for advice {no britpart }
12th Apr 2020 8:13am |
