Home > Maintenance & Modifications > Rear door sill replacements tips
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Hi All, in my lockdown quest of tidying up the rear end of my 90 I am looking at changing the rear door sill that looks like it has come off the titanic (as pictured below).
I have the part from PowerfulUK (https://www.powerfuluk.com/land-rover-defe...l-kit.html) however was wondering if anyone having done this themselves have any tips or tricks?
I also really want to retouch the green paintwork around the rear body mount fixings- my first time painting any body work- is it quite easy to a good finish with etch primer and a spray can if the area is sanded down well? Any advice gratefully received!
 Keswick green 2007 Defender 90 TD5
Post #824287 9th Apr 2020 4:14pm
Its' really just a case of unscrewing the fixings from the old one, lifting it out, cleaning out accumulated crud and replacing with the new one. It only becomes more difficult if the screws are rusty, which may mean they have to be drilled out. On a good day, it's a ten minute job. Darren
Post #824289 9th Apr 2020 4:23pm
Mdm
don't leave it as long as this one.
they used bigger slotted screws as well.
when you fit the new one use plenty of anti rust grease paste or coppaslip on the screws and bottom of the plate unless its a stainless one.
this put a good fight up but lost in the end.
Post #824336 9th Apr 2020 8:44pm
MarcusM
Turned out to be the unfortunate option of drilling it out LandRoverAnorak but managed it in the end!
Thanks for the tips Mdm to be fair mine looked pretty bad once I’d taken it off! Gave it a bit of a respray whilst off too which tidied up the rear body mount holes.
Post #824478 10th Apr 2020 9:02pm
Mdm
looks better now
Post #824480 10th Apr 2020 9:04pm
Co1
That looks great, top work! 👍
Post #824518 11th Apr 2020 7:51am
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Looks good! By the way, what did you paint your crossmember with (I need to do mine)?
Post #824520 11th Apr 2020 8:00am
MarcusM
Thanks Co1 & Mdm.
Doc P did it with the kit from
Buzzweld- highly recommend just spend a lot of time getting it prepped before starting-
https://www.buzzweld.co.uk/fxliner-1k-cros...g-kit.html
Post #824529 11th Apr 2020 8:45am
stephan123
Doing mine tomorrow. Will post pics!
Post #824655 11th Apr 2020 8:17pm
Sulisuli
Nice tidy work there Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #824662 11th Apr 2020 8:29pm
Looks great Thumbs Up Darren
Post #824669 11th Apr 2020 8:46pm
MarcusM
Thanks guys and good luck Stephan123! Keswick green 2007 Defender 90 TD5
Post #824681 11th Apr 2020 10:07pm
keith
A lovely clean job. Is the door seal upside down?
Keith
Post #824723 12th Apr 2020 8:54am
MarcusM
Neutral Not sure Keith- I was trying to work it out when I was fitting it. Door seems to close well against the seal but it could well be upside down- I’m very new to all of this!
All I know if it is upside down it’s staying that way! Keswick green 2007 Defender 90 TD5
Post #824729 12th Apr 2020 9:14am
keith
Looks like the channel in the rubber should be to the underside but may well not make much difference.
Iv also got mine off and of course there had to be one screw break off. Big Cry
Keith
Post #824757 12th Apr 2020 11:20am
