![]() | Home > Maintenance & Modifications > Rear door sill replacements tips |
MarcusM Member Since: 29 Jan 2020 Location: Nottingham Posts: 101 ![]() ![]() |
Hi All, in my lockdown quest of tidying up the rear end of my 90 I am looking at changing the rear door sill that looks like it has come off the titanic (as pictured below).
I have the part from PowerfulUK (https://www.powerfuluk.com/land-rover-defe...l-kit.html) however was wondering if anyone having done this themselves have any tips or tricks? I also really want to retouch the green paintwork around the rear body mount fixings- my first time painting any body work- is it quite easy to a good finish with etch primer and a spray can if the area is sanded down well? Any advice gratefully received! ![]() Click image to enlarge Keswick green 2007 Defender 90 TD5 |
Its' really just a case of unscrewing the fixings from the old one, lifting it out, cleaning out accumulated crud and replacing with the new one. It only becomes more difficult if the screws are rusty, which may mean they have to be drilled out. On a good day, it's a ten minute job. Darren
Turned out to be the unfortunate option of drilling it out LandRoverAnorak but managed it in the end!
Thanks for the tips Mdm to be fair mine looked pretty bad once I’d taken it off! Gave it a bit of a respray whilst off too which tidied up the rear body mount holes. ![]() Click image to enlarge Keswick green 2007 Defender 90 TD5 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
looks better now
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
That looks great, top work! 👍
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Looks good! By the way, what did you paint your crossmember with (I need to do mine)?
Thanks Co1 & Mdm.
Doc P did it with the kit from Buzzweld- highly recommend just spend a lot of time getting it prepped before starting- https://www.buzzweld.co.uk/fxliner-1k-cros...g-kit.html ![]() Click image to enlarge Keswick green 2007 Defender 90 TD5 |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 285 ![]() ![]() |
Doing mine tomorrow. Will post pics! |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
Nice tidy work there
![]() 2008 SVX 90 2000 XS TD5 90 |
Looks great ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks guys and good luck Stephan123! Keswick green 2007 Defender 90 TD5
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
A lovely clean job. Is the door seal upside down?
Keith |
![]() All I know if it is upside down it’s staying that way! Keswick green 2007 Defender 90 TD5 |
Looks like the channel in the rubber should be to the underside but may well not make much difference.
Iv also got mine off and of course there had to be one screw break off. ![]() Keith |
