![]() | Home > Maintenance & Modifications > Installing a hatch for Td5 Fuel pump access |
conornm Member Since: 15 May 2022 Location: Portsmouth Posts: 7 ![]() ![]() ![]() |
I need to do this on my 110 hardtop; does anyone know the measurements for where I should drill the hole?
Also is a 7” inspection hatch big enough? Thanks. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6158 ![]() ![]() ![]() |
https://www.defender2.net/gallery/albums/u...ola110.pdf
This is the doc I used for my 110. I got the inspection plate from a discovery series 1, which handily has a hole already cut in the tub. You just need some of the plastic square nut inserts so you can screw in a self tapper. Last edited by diesel_jim on 7th Feb 2025 8:43pm. Edited 1 time in total |
Thanks very much.
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 235 ![]() ![]() |
I know I should do this to my 130 but I have a non standard fuel tank and a non standard rear tub, it would end up looking like a blind man looking for buried treasure🤷♂️
