![]() | Home > Maintenance & Modifications > 2" Tow Ball |
Mumpa Member Since: 23 Nov 2019 Location: Alberta Posts: 12 ![]() ![]() ![]() |
Gents.
Having imported my 2004 90 to Canada, the existing tow ball is 50mm but the trailers here are 2". I used a trailer last weekend and although it fitted, there was far too much wobble. The flange mount type tow balls are not common here at all, pretty much finding nothing. They all use a 2" tube. Does anyone know either of the following: Could I get a 2" flange type ball? If so, where? Could I get a 2" square mount so that I could use the types of tow balls over here? Thank you in advance |
I'm not sure about getting a 2inch flange type ball. They haven't been used for decades over here. You can, however, buy a 2 inch receiver hitch for your Defender that will allow you to use local towing equipment:
![]() Click image to enlarge Mine's made by Safari Equip and was purchased from 4x4 Overlander.com. There's also a similar version offered by Terrafirma. I hope that helps. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Yep, I have the Terrafirma equivalent, and it's also excellent, either would do the job.
Also check this out: https://www.watling-towbars.co.uk/import_vehicle_towbars.html --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Thats exactly what I am looking for.
If you don't mind sending the CAD drawings, that would be great, I would really appreciate that, thank you ![]() ![]() Shipping costs to Northern Alberta are somewhat expensive from the UK, ![]() ![]() |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Send me a PM with your email. North Cumbria Search and Rescue - Team Leader
