![]() | Home > Td5 > Fuse 2 on Hi Cap(2003) |
fuse 2 feeds auxiliary 110 hi cap But only runs down chases and not up to light cluster
check battery neg from battery down to the chases and transfer box also from chases to the body work driver side under neath engine end red plug ECU have oil in it ![]() |
claxby Member Since: 30 Sep 2019 Location: le14 Posts: 27 ![]() |
All hunky dory on the earth front, although I may add extra.
Occasionally starter refuses to come in, have checked solenoid, and the relay is new...I wonder if there is a fault on the ignition switch allowing a back a feed to the ECU??? Will fit a new one to prove. Do you know where the aux terminates on the chassis ?? Red con on ECU ok, Otherwise runs ok. |
follow chassis loom at back driver side you shod find small wire tail Purple with black boot over end just before loom go up light cluster |
