Home > Technical > Can someone send me a standard def td5 fuel map please?
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Currently running a disco map fro the replacement nnn ecu.
I thought i was going to be able to rip the original defender map from my old msb ecu but nanoncom says no due to it being an msb. If someone with a nanocom is bored and could pull their fuel map for me id be greatful.
With the disco map its jerky at low speed i have to drive flat out Whistle
EDIT: Found the nanocom map wizard with all the maps i could ever need. Flashed a ROW spec map on as i have my egr removed anyway. Cool
Post #822516 31st Mar 2020 3:01pm
Martin
Site Admin
IIRC you can get the standard maps out of the “Map Wizard” program Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #822523 31st Mar 2020 3:48pm
