Home > Puma (Tdci) > No torque when cold |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Is there an rev hunting on idle when stone cold. I.e. minor RPM fluctuation?
Have you managed to or have capability to check for Diagnostic Trouble codes? It could be the VCV but there usually are some symptoms of that. Is there Power there towards 60mph + or does it seem like you need to push it? The VCV doesn't flag DTC's but the other two symptoms are that I found mine had. You may have DTC's logged for other issues though so may be worth checking. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
25th Mar 2020 9:39pm |
