![]() | Home > My Defender > a 130 itch |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
How much does the stat open? What the range of movement 12mm or more? Cheers
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 729 ![]() ![]() ![]() |
Unfortunately at the time I didn’t actually measure how much it opened, it appeared to open its full range of motion, a good 10mm by eye.
A correctly functioning stat is crucial. Of the Mahle ones I have only two from 8 opened at correct temp and opened fully. Cheers
I’ll whip the stat out again and have a measure up as soon as I can.
Looks like Marcus at MWmachines is working on a thermostat to help with this problem so I may look into that at some stage. One last question and I’ll leave you alone, Davis Craig recommend drilling two holes to help circulation, did you do this or do you think it’s not necessary if the stat is (should be) open when the pump switches on? |
Mine is connected is such a way it can only come on when the stat is open so, no I didn't drill any holes.
Marcus and I have been discussing stats alot. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks again James, all very appreciated information
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 344 ![]() ![]() ![]() |
Thanks, will have a look ![]() Can you elaborate on the "not so great" finish? Is it fit or longevity you're not so impressed with? Defender 130 HCPU Td5 MY2000 |
the paint comes off Cheers
Good to know, thanks! Defender 130 HCPU Td5 MY2000
