Home > My Defender > a 130 itch
Page 8 of 21 <123 ... 789 ... 192021>
jst
Managed to spend some time on her today.
Disappointing to find no grease or oil in the osf swivel housing!
Even more surprising to find this dwarf in the front diff pan!
Ashcroft rear hypoid locker is a beast, look at the size of that crown wheel compared to std one on the left.
Rear shafts, rear locker in, new discs and calipers and rear flexi fitted along with replacing the wheel bearings.
Front diff is out, cvs both out and old brake parts removed. Refit tomorrow time permitting.
Also disappointing to see that despite it being an 11 plate and 10my onwards was the change, it had a std 2 pin front diff. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #828795 1st May 2020 5:20pm
Mdm
lucky that you had a look in there.
loads of 2 pins were used instead of 4 pins , cutting corners then and now at lkr.
cant wait to see it on the road
Post #828805 1st May 2020 6:40pm
jst
with luck front axle will be finished tomorrow, time permitting. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #828812 1st May 2020 7:46pm
Looking good James
Post #828813 1st May 2020 8:18pm
familymad
You are spending your lockdown cash fast..... love your work Rolling with laughter 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #828833 2nd May 2020 6:02am
jst
Self employed and cant work, may as well have a project, to be fair ashcrofts kit ordered before lockdown. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #828943 2nd May 2020 7:01pm
jst
A good morning on it today, gwyn track rod guard and sumo track rod fitted after the Ashcroft front diff had gone in.
Anyone know if you can run anti roll bars front with this guard. It physically fits, just not sure it has the space for functionality. Will ask Gwyn after weekend.
Ashcroft shafts and cvs in joined with their drive members to keep the oil on and crud out. New discs, bearings and my old 110 calipers with Zeus pistons fitted along with chassis to caliper braided hoses from llama4x4
As you will see from pic 11year olds helping with the copper slip again!
Need to adjust the tracking tomorrow and reduce the brake pedal free movement. Locker switches to wire in when my 2nd hand mss cubby turns up.
I am quite pleased with it, it's coming along nicely.
One slight lighting issue which I will post separate on.
Now rear canopy fabrication work...... it will have to go to someone for that. Any recommendations in the sw? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #828966 2nd May 2020 9:06pm
jst
Fitted mss 2nd hand cubby yesterday and cb along with some cut outs for the locker switches, just need to finish wiring them up.
Raptor coating eventually arrived so prepared, primed and applied the load liner to rear tub. Typically after 3 bottles and one 8" section to go the gun jammed up, so the one messy finished bit I have is right at the tailgate on the bit that's not going to be covered! Just my luck
I used a buzzweld primer then liner straight on top with schultz (?) Gun. Went only quickly and easily less gun binging up towards the end. Currently waiting for it to dry.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830133 9th May 2020 6:04pm
Co1
It’s a good finish isn’t it. By the way, nice workshop!
Post #830183 10th May 2020 6:08am
jst
Yes it comes up really well and looks good. Quite impressed with its ease of application and looks so far will see how it goes on durability. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830260 10th May 2020 12:51pm
jst
Well, heated seats now fixed.
Slight prop vibration, the machine shop who shortened it didnt balance it very well it seems.
Been to see various fabricators and vehicle is off over the weekend to have the conversion to full hard top done. About a weeks work. Will give them 2. Thank fully hes a very good friend and I trust him fully for the work.
Been a busy week, have collected a 110 roof and an 88 roof. Both ribbed with early stronger galvanised gutter. These will be joined for the full roof to rear. Collected some series sides to, these will run back from c pillar for 8inches or so before tying into customers back coming up off the hi cap tub.
Picked up some latches for the three rear up and over doors from Exmoor trim today along with a cubby box and two recovered 2nd hand seats, ebay specials. They were to replace the rear 60/40 but I think they will be going in the front and the fronts will be moved to the rear.
regassed the air con to find the oil/dye on the floor the following morning, new condenser needed!
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832706 22nd May 2020 8:10pm
jst wrote:
... Even more surprising to find this dwarf in the front diff pan ...
I cannot begin to imagine your surprise at finding a dwarf in your diff! I Rolling with laughter
Don't you just love spellcheckers!
Post #832709 22nd May 2020 8:33pm
jst
he was tiny, you can just about see his face in the picture! Shocked Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832720 22nd May 2020 9:26pm
jst
Well I needed to get a 110 roof and switch roof to the fabricator, so thought i may was well fit the 110 roof to get it there.. does look odd! Rear seats out along with the seat box now to.
Last pic shows the angle sides will be from hicap tub to the roof. Less gutter!
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832970 23rd May 2020 8:11pm
jst
Well she is all loaded up and ready to go to fabricators tomorrow. All very exciting. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #833303 25th May 2020 2:06pm
