Home > Maintenance & Modifications > Nakatanega Bolt kit
Kilvo1
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Baltic Blue
Nakatanega Bolt kit
Hi
I have a set of Nakatanega stainless bolt to fit and I wondered about the amount and place to smear the paste supplied, anyone out there with the answer?
Post #820600 22nd Mar 2020 9:10am
Andrew james
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
Put a blob on each of the bolt threads.
Post #820607 22nd Mar 2020 9:49am
discomog
You're trying to stop or should I say reduce the amount of galvanic corrosion that takes place between two dissimilar metals so therefore I would smear paste not only on threads but on any surface where the two metals touch. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #820616 22nd Mar 2020 10:58am
grafty99
When I did mine I also put nylon washers underneath the tub to crossmember bolts to prevent corrosion. Still good 3 years later Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #820699 22nd Mar 2020 6:31pm
