Home > Maintenance & Modifications > Nakatanega Bolt kit |
Andrew james Member Since: 02 Jan 2013 Location: Awliscombe Posts: 88 |
Put a blob on each of the bolt threads.
22nd Mar 2020 9:49am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
You're trying to stop or should I say reduce the amount of galvanic corrosion that takes place between two dissimilar metals so therefore I would smear paste not only on threads but on any surface where the two metals touch. Defender 90XS SW
22nd Mar 2020 10:58am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4793 |
When I did mine I also put nylon washers underneath the tub to crossmember bolts to prevent corrosion. Still good 3 years later 2002 90 Td5 Station Wagon
22nd Mar 2020 6:31pm |
