Home > Technical > Beep from the alarm on start up
discomog
Puma 2.2
When I turn the ignition key to the Aux position it brings up the glow plug warning light. As soon as the light extinguishes I turn the key to the start position and the vehicle starts up OK.
If however I turn the ignition key and go straight to the start position (ie not pausing to extinguish the glow plug warning light)
then the alarm emits a loud but short beep. Is this an alarm problem in the making and/or has anyone else experienced this phenomena? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #819912 16th Mar 2020 8:44pm
ickle
Low battery? Glow plugs taking their whack at the same time as the starter motor?
Post #819916 16th Mar 2020 9:04pm
Martin
Site Admin
Low battery - I get a chirp on start from my 2.2 if it’s been sat for more than a week or so.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #819922 16th Mar 2020 9:41pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Yes, I get the same, I keep thinking about a trickle charger which I have on a couple of other vehicles.
Post #819929 16th Mar 2020 10:33pm
discomog
I use a Thumbs Up Ctek 5 charger. Battery voltage is at 12.6 volts. Haven't tested the voltage during start up. Not too concerned as other forum members seem to experience the same bleep/chirp on start up. i was just worried that the alarm may be starting to play up. Fingers crossed Defender 90XS SW
Morgan Plus 8
Post #819967 17th Mar 2020 11:22am
