Home > Technical > 12V actuators for LT230 hi/lo and difflock
Bumpydog
Ireland 1989 Defender 90 300 Tdi CSW Auto Bonatti Grey
Has anyone installed 12V actuators to select hi/lo and/or difflock? I am contemplating installing two linear actuators via DPDT switches on the dash. The reason I am doing this is that I have limited space for the standard lever. I have a 1989 90 with 300TDi engine and auto box and an Ashcroft console.
Given that the auto box and transfer box is from a Discovery 1, would the transfer box have a low-range selected switch as well as a difflock selected switch? I've yet to lift the floor and tunnel to check.
The biggest challenge is making suitable mounting brackets for the actuators, but I can see no reason why this solution wouldn't work.
Anyone have any experience in this area?
Thanks.
Post #819264 12th Mar 2020 12:13pm
VVS210
There is not switch for hi/low on the D1 transfer box as I recall, only one for the diff lock warning light. D2 transfer boxes have a switch for hi/lo but finding one with a diff lock isn't easy!
Have you thought about using the cable arrangement for hi/lo from a D2 transfer box? - they are readily available and mean you can locate your shift lever to suit. For the diff lock, there's a guy on the D2 Boys Club forum who makes and sells vacuum actuator kits, complete with all the brackets to fit them and switch to actuate them.
Post #819273 12th Mar 2020 1:31pm
Bumpydog
Thanks for the reply. My problem is the lack of space forward/back. Selecting difflock is less of an issue. Do you have a link for the vacuum actuator solution? Is it for hi/low as well as difflock? I sort of thought that the D1 LT230 doesn't have the hi/lo select switch. Doesn't the D2 LT230 have difflock but no actuating method (hence the aftermarket kit)?
Post #819276 12th Mar 2020 1:43pm
VVS210
D2 LT230s don't all have diff locks, they are more common in pre-facelift cars but the 2002 onwards cars only had them as options although there is an urban myth that in 2004 at the model run out they all had CDL even if there was no linkage to lock the diff itself - I say urban myth as all the '04 cars I've seen actually don't have CDL fitted!
Will look to see if I can find a link to the pneumatic actuator and PM it to you, it only does the diff lock not hi/lo though - not sure if you will be able to see the thread though as I am pretty sure the D2 Boys Club does not have public access.
Post #819314 12th Mar 2020 6:12pm
ibexman
Here
Deleted
Post #819319 12th Mar 2020 6:28pm
Bumpydog
I've checked your message (I need to have 3 posts under my belt to reply to your PM!!!)
Post #819320 12th Mar 2020 6:32pm
bankz5152
You can buy a pnuematic set for difflock so a 12v system would be fine.
I think you would struggle to get lo/hi to work well. Instagram @defender_ventures
Empire Tuning - Agent
Post #819324 12th Mar 2020 6:42pm
Mo Murphy
Why do you have no room with ashcroft auto console ?
There's a square hole in it for the transfer lever.
50 Shades of Pennine Grey
Post #819327 12th Mar 2020 6:51pm
jst
You could remote the hi low like an underdrive lever Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #819359 12th Mar 2020 9:46pm
Bumpydog
Mo
My 90 has a Puma dash. Whoever installed the Disco engine/transmission also put a bend in the hi/lo lever. If I straighten the lever, it won't go far enough forwards into low to clear the dash (heater motor?). I've yet to try straightening the lever slightly, to allow fitment of the knob (in high position) but I'm expecting it to not properly engage low range. The other issue is that it requires quite some effort to shift to low/lock, which might stump my missus from using it.
Post #819414 13th Mar 2020 11:38am
Mo Murphy
Could you try a smaller knob ?
Post #819451 13th Mar 2020 5:02pm
