![]() | Home > Tdi > Fitting 300Tdi into LHD N/A exmod 90 with LT77 |
Racedriver Member Since: 24 Jan 2019 Location: Buckinghamshire Posts: 117 ![]() ![]() ![]() |
Just a thought, do you have a short bell housing? if so maybe a long one would bring the engine forward. 300 TDI's were fitted in LHD models so it must be possible.
Greg L Member Since: 30 Sep 2013 Location: Alexandria Posts: 46 ![]() ![]() ![]() |
Longer bellhousing would require different gearbox and knock out the engine mounts as I want to be able to fit a N/A in the future.
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 539 ![]() ![]() |
Have you asked steve parker for advice he may have a solution already available.
I have asked Steve Parker and got ignored even though I’ve spent fair bit at his shop including the engine mount kit, got great advice from glencoyne engineering, like swapping exhaust manifold for a 200tdi unit as outlet is further forward, possible clocking of turbo. Seen a 300Tdi in a LHD series 3 and they clocked turbo and relocated alternator. Got loads of intercooler hose and tubing but currently can’t get near project due to lockdown. Didn’t think I’d be the only one to come against this before. A bit disappointed in Steve Parker as this is the second issue he has ignored my call for assistance.
